bug in bridge function in looptools #34801
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#34801
Project: Blender Extensions
Tracker: Py Scripts Release
Blender: 2.66
Script name: mesh_looptools.py
Wiki page: http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Modeling/LoopTools
Author(s): Bart Crouch
Category: Mesh
Status: Open
%%%The bridge function in loop_tools is producing incorrect results on the second and subsequent uses. The problem occurs when the remove faces check box is selected (the default). The first time through it works fine but the next time you use it the wrong faces are deleted and also the wrong faces are selected at completion.
I've debugged this myself and the problem results from the re-use of previously deleted faces in the bm.faces list. New faces are not always added to the end of the list and this causes access of the face list by index to return incorrect results. The functions bridge_select_new_faces and bridge_remove_internal_faces need to be updated produce the correct results.%%%
Added subscriber: @brecht
Fixed in local development version. Will commit in the upcoming week.
This issue was referenced by
4b7f9c6819
Closed by commit
4b7f9c6819
