No Disc Error when starting Blender #34929
Reference: blender/blender#34929
Windows 7 Pro with a ati 5770 Radeon Card
In Blender 2.66.1 released version
When trying to start blender, it will only show "No disc" error. It will not allow the system to bypass the error or ignore it. It will just keep repeating the popup of "No Disk" for the DVD drive.
What the problem ended up being is that the file "C:\Robert Broughton\AppData\Roaming\Blender Foundation/Blender\2.66\config\recent-files.txt" had listed some files on the removable DVD drive in its list:
"C:\Users\Robert Broughton\Documents\Blender\Practice\untitled.blend
C:\Users\Robert Broughton\Documents\Blender\Practice\Test.blend
D:\Users\Blender\Models\headmesh.blend"
So when the DVD was removed, Blender would not start, it would only give the "No Disc" error.
Two temporary work around is to 1. Put the removable DVD back in, 2. Modify the "recent-files.txt" file so it doesn't have the D: drive file in the list. However, the fix would be to allow blender to continue even if it can't find a removable file.
Thanks for the great SW.
Bob%%%
%%%I tried to redo the issue but couldn't, with Blender 2.66a on Windows 7 64 bit. Steps I tried:
> All that happens here is that the entry is not listed anymore in recent files.
Is this a new issue in 2.66 or did it happen in 2.65 too? The code to detect if a file exists changed recently, so perhaps it's because of that. But I don't see anything particularly suspicious there.%%%
%%%Here is what I just tried and it showed the error again.
1, Put the Track Match Blend disc into the DVD drive.
2. Go to the DVD D:/blendfiles/01_introduction/01_1pointtrack/1pointtrack.blend and open the 1pointtrack.blend file in blender
3. Save file on Windows Desktop
2. Go to the DVD D:/blendfiles/01_introduction/01_2pointtrack/2pointtrack.blend and open the 2pointtrack.blend file in blender
4. Save the file on Windows Desktop
5. Quit Blender normally.
6. Remove the DVD disc.
7. Open Blender. Error repeats.
If you only do it with one file, then you will have the option of continuing. It only happens when I open two or more different files then save them to the local drive.
Note: It can be any 2 blend files loaded from the DVD drive and saved to the desktop after opening, it doesn't have to be the TRACK MATCH BLEND disc.
I didn't try this under 2.65, but I didn't have any blend files on the DVD.
Hopefully this allow you to replicate it.
Thanks
Bob
%%%I am able to reproduce this with 2.66.5 r55932 and with 2.66.0 r54697.
Versions 2.64 and 2.65 don't dipslay this behaviour. Here they just skip missing entries.
The easiest way to reproduce is to add an entry in recent-files.txt to a file on a removable disk. I.e. I added E:\blends\tutorials\critters.blend from the mancandy faq as entry, then made sure nothing was in the drive. Starting Blender then gives the error message. One can continue by pressing the Continue button, though.%%%
%%%What happens with me is if there is two or three files in the recent-files.txt that point to a removable drive, then the Continue button won't work either. It then has to be stopped by the task manager.%%%
%%%I was able to redo the issue now on another computer, and the problem happened also in 2.64 and 2.65.
Fix in svn now, thanks for the report.%%%
