Print3D Toolbox -- Intersection bug #35123
2 Participants
Reference: blender/blender#35123
%%%OSX, 2.67RC1
mesh.print3d_check_intersect() does not work, even for simple cases.
I attached a .blend file. There are 3 identical mesh objects in it, except that each one has been translated (in local coordinates, not using object.location) by a different amount.
Run mesh.print3d_check_intersect() (from the new print 3d addon in the sidebar) on each one. Each will label a different number of faces as "self-intersecting" even though none of the faces are intersecting.
It appears to be related somehow to the concavity and to normals, which may be just a design limitation, but it is also affected by translating the mesh, which is quite illogical.
Note that the "Mesh Analysis" function in the Toolshelf (N) does not appear to have this issue.%%%
%%%Wait, should I have reported this bug under the addons tracker, since the Print3D toolkit is an addon?
If that's true, my apologies. I can repost it there.%%%
%%%Someone else seems to be having trouble in the forums:
http://blenderartists.org/forum/showthread.php?292770-How-accurate-is-the-Print3D-addon
It's not quite the same as my bug, but perhaps it's related.%%%
%%%The intersection tests can be improved but when you move far the center point you start to loose precision (which is the cause of the problem).
this is more of a todo then a bug,
closing.%%%
Changed status from 'Archived' to: 'Resolved'
Resolved blender/blender-addons@30e801eb06
