"Weight Paint Sample Group" popup in Weight Paint mode overrides shift+rmb input.
Closed, InvalidPublic
Windows 7 Pro
Geforce 660ti SC
tested and was found in both 2.66a and 2.67rc1
Any time shift+rmb is used while in Weight Paint mode a single line popup box appears that says "Weight Paint Sample Group". It appears to do nothing and overrides any/all operators assigned to that key combination. I used the 2.67rc1 feature for looking up inputs by key binding in order to turn it off but was not able to find it there.
Simply go in to weight paint mode and press Shift and the right mouse button anywhere in the 3D View.
Actually it looks like "Weight Paint Sample group" can be turned off in input, but shift+rmb still wont work for Lasso Select.
Figured it out. This can be closed.
Lukas Toenne (lukastoenne) changed the task status from Unknown Status to Invalid.Apr 30 2013, 9:24 AM
I just encountered this. How did you fix it?
