Edge Slide via the GG shortcut can show incorrect selected checkboxes
Open, NormalPublic
Windows 8 x64, GTX560SE
2.67 r56888
Edge Slide via the G-G shortcut can show incorrect selected checkboxes in Tools Shelf: http://i.imgur.com/eNwW8Kj.gif
Open attached .blend file. With an edge selected, use "Edge Slide" button in Tool Shelf. Click on checkbox "Correct UVs". Select another edge and now use Edge Slide via the G-G shortcut - tool behaves as if "Correct UVs" selected, but it's showing unchecked in Tools Shelf.
Thanks for the complete report. As far as I know our operator redo should work fine, so there's an issue with the properties for the tool.
Need Campbell to check.
Transform is unique, in that it can change operators while running,
I've already worked around some bugs caused by this but think it may be best to remove this functionality (add it back implemented differently).
The problem is if you press G, then R - The operator properties transform dont necessarily apply to rotate.
Id propose we have a way for modal operators to cancel themselves and trigger another operator - to avoid these kinds of glitches.
@Campbell Barton (campbellbarton), what would be the verdict here? Seems more like a design limitation..
Chanced status to TODO, we can't *fix* withs without a re-design.
