Project timer in Info window
Open, NormalPublic
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.66
Category: User Interface
Python: 3.2
Script name: Project Timer
Author(s): Martin Zielinski
Status: Open
Timer located in Info window that indicates time spent on particular project. Time values are stored in blend file to keep record.
Timer is refreshed along with Info window so moving mouse over Info window is needed to see updated time.
Now timer will stop counting when you stop working for longer than 30s
Nice addon, you should add a wiki page!
I love this Add-on! But I have a problem. Since I have saved my startup file the time starts at about 15:45 when I open Blender. So if there is a possibility to add a reset button that would be great!
Thanks
M Z (lemi) added a comment.EditedMar 26 2016, 6:03 PM
I'm not sure where I should add this file (I can't edit my task?), so I put it in this comment.
I added project timer reset button to addon's preferences.
Thanks a lot! That works pretty well! Although I can only get it to start at about 5-7 seconds due to having to update the timer with the mouse and then saving the settings.
This is really good enough but It's got me wondering, I have no experience with programing but would it be possible to get it to always start at 0?
Sorry if I'm asking too much. I really appreciate your work!
Thanks
Try this:
  1. Open Blender
  2. Disable Project Timer add-on
  3. Open Python Console area and type ` C .scene.projectTime = 0 `
  4. Overwrite your startup file and reboot Blender
  5. You can enable add-on again
Happy Blending
Now that works great! Thanks a lot! :)
Aaron Carlisle (Blendify) raised the priority of this task from "Normal" to "Needs Triage".Mar 28 2016, 11:49 PM
Waiting for re-triage this is quite old and note sure if this is worth it. It may be worth adding to another addon such as the Amaranth Toolset or Scene Information
Sergey Sharybin (sergey) triaged this task as "Normal" priority.Mar 29 2016, 10:21 AM
We'll be reviewing this later.
