Convert slopes to vertex group weights #36677
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#36677
Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.66
Category: Mesh
Python: 3.2
Homepage: http://blenderthings.blogspot.nl/2013/09/slope-to-vertex-weights-blender-add.html
Script name: slope2vgroup
Author(s): Michel Anders (varkenvarken)
Status: Open
%%%Addon to convert slope (angle between vertex normal and object space z-axis) to vertex weights. Its purpose is to facilitate distributing particles preferentially to relatively flat parts of a mesh.
workflow:
it will replace the vertex weights of the active vertex group or create a vertex group if none is present yet.
Then add particle system as you normally would and select the vertexgroup in the density field
%%%now has dual functionality
3dview -> Weights -> Slope will create/replace active vertex group weights
3dview -> Paint -> Slope will create/replace active vertex color layer (red channel)
Has now 4 options
low : slopes with lower angle than this will receive a unit value
high : slopes with steeper angle than this will receive a zero value
power: influences the shape of the mapping curve
mirror: maps slope angles > 90 to 180 - angle
%%%v0.0.3 adds mirror option and the possibility to map the brush curve in vertex paint mode%%%
%%%v0.0.4 adds possibility to calc slope in either worldspace or object space coordinates in both vcol and vweight modes. vcol mode now produces grey scale values for the slope unless normal map is checked in which case the x,y,z components are simply mapped to the r,g,b component of the vcol layer.
Added subscriber: @BrendonMurphy
Closing as archived.
@MichelAnders
Feel free to create a fresh task if you intend developing this in Blender. It would be nice to some of this functionality in ant landscape.
