UV Project from View Gives Distorted results #37022
Reference: blender/blender#37022
)SX 10.6.8, AMD Radeon HD 6770M
r60597, unknown
When using the project from view UV unwrap option the resulting UV Map is distorted especially when repeating the image
Open default scene, go to camera view, scale cube to larger than size of camera frame, go to edit mode, UV unwrap using the project from view option and add an image to the material of the object with UV mapping as texture coordinates.
%%%As far as I know that is not a bug, just annoying behavior. You get the same problem with the UV-Project Modifier. In that case use a Subsurf Modifier on your model and set it to "Simple" instead of "Catmull-Clark". Increasing the subdivs to 2-4 should be enough.
Simply subdividing the object a couple of times in EditMode in the attached file also does the trick.
%%%I've known of this fix for a while, but its a very impractical one. Is this all determined by the UV unwrapping math used for the project from view?%%%
%%%Blender internal has an option to handle the UV interpolation for projection, Options panel -> UV Project,
But currently cycles doesn't have this.
This is more a missing feature then a bug.%%%
%%% Oh, ok. Thanks for the clarification!%%%
%%%This is indeed a todo item, not considered a bug at the moment.%%%
%%%Awesome! Looking forward to this feature!%%%
