GLSL/Matcap shading not working #37259
Reference: blender/blender#37259
Comp: Dell Vostro A860 Laptop
OS: Windows Vista Home Basic SP2 32-bit
CPU: Intel Celeron 560 @ 2.13 GHz
RAM: 3.0 GB
GPU: Intel GMA 965, drivers are as up-to-date as possible
Blender 2.69, also happens in 2.68
Worked in 2.67b
All are 32-bit versions
Blender will only render a Black/Green/Orange solid colored geometry (likely for the outline) when using GLSL shading mode or Matcaps. BGE only shows solid colors like white, black, grey, etc. Multi/Singletexture shading works fine.
This happens on all .blend scenes including the start scene.
Console spits out this message as well:
GPUShader: linking error:
Fragment shader uses varying gl_FrontFacing but vertex shader does not write to it.
What does that error mean in plain English?
Use an ancient (2008-era) computer w/ Intel GFX maybe?
%%%See attached image to see issue.%%%
%%%This issue is caused by really poor GLSL support and doesn't have functionality to properly. The changes which made shading not working for you were caused by a bug fix at svn rev57702.
Brecht, perhaps we could try faking gl_FrontFacing for the cards which doesn't support it, or just consider this GPU as not supported for GLSL shading?%%%
%%%This is a driver bug, this variable should be supported in any GLSL version, and the error message makes no sense. The GLSL specification says this is a read-only builtin variable, and it would not actually be possible to to determine its value in the vertex shader. The latest driver for this card is from 4 years ago, so that means Intel will not fix this bug.
We will soon make even more changes that require a good OpenGL implementation, so I think we just have to accept this as a graphics card / driver combination that we can no longer fully support. It would be nice to support some sort of OpenGL software rendering fallback at some point, but I would not consider that a bug.%%%
%%%How would I be able to fix this myself within Blender (apart from acquiring a new computer)?%%%
%%%If you compile your own Blender, you can revert the changes. Basically you go into the folder source/blender/gpu, and replace every mention of "gl_FrontFacing" by "1". This will give incorrect lighting in some cases, but this feature is needed to handle lighting correctly. That or avoid using GLSL mode.
I'm sorry I can't give a simpler answer, but we can't support such older cards well while keeping things working correct and with good performance on newer cards too.
