'Redo' panel: Some redo settings don't make sense to edit
Closed, InvalidPublicDESIGN
Issue Description:
Some tools, such as Move Up/Down Modifier (arrow in the Modifier list) was never meant to be tweaked.
Proposed Solution:
Remove operators from redo panel that don’t make sense to be user-tweakable
List of useless redo options
  • Move up/Move Down Modifier (click arrow in Modifier Properties) shows a useless text field
  • Add Modifier redo (I can't see how this makes sense)
  • Remove Modifier shows a useless text field
  • Move/Rotate/Scale object: 'Confirm on Release' in redo panel. Makes no sense to tweak that
  • Move/Rotate/Scale object: 'Edit Texture Space' in redo panel. Makes no sense to tweak that
  • More?
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to Normal.Nov 14 2013, 2:05 PM
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Unknown Status.Mar 10 2016, 6:49 AM
No resolution or activity in over 3 months,
archiving, listed in the wiki.
Can re-open when we have time to handle this one.
Going through old UI ToDo tasks - for the new floating redo region, quite some operators were updated to address the issues mentioned here. Marking the ToDo item as done.
