More descriptive tooltips for freestyles settings
We had a conversation on FB about FS in general.
Involve a big number of freestyle users.
We had tons of feedback.
We found out few tooltips in need of urgent fix.
I also include suggested tooltips.
They are
  1. Edge types:
    • silhouette (select outer contour & inner closed mesh edges with depth differences),
    • border (select open mesh edges),
    • crease (select edges by minimal face angle set by crease angle),
    • edge mark (select marked edges),
    • contour (select outer edges of each object),
    • external contour (select external edges of a group of object),
    • suggestive contour (select almost silhouette/contour edges)
    • ridge and valley (select edges when faces direction change from concave to convex)
  1. Face mark (//don't use "negation operation" here)
    • Inclusive (include marked faces to edge detection)
    • Exclusive (exclude marked faces to edge detection)
  1. Group (//don't use "negation operation" here)
    • Inclusive (include object group to edge detection)
    • Exclusive (exclude object group to edge detection)
  1. Line style > Thickness > Position
    • Inside (move edge inside for outer edge types when chaining enabled with type plain & same object activated)
    • Outside (Move edge toward outside for outer edge types when chaining enabled with type plain & same object activated)
    • Relative (relative position for outer edges when chaining enabled with type plain & same object activated)
WK Bong (lightbwk) raised the priority of this task from to Needs Triage by Developer.
WK Bong (lightbwk) updated the task description. (Show Details)
WK Bong (lightbwk) added a project: Freestyle.
WK Bong (lightbwk) set Type to Design.
Tamito Kajiyama (kjym3) lowered the priority of this task from Needs Triage by Developer to Normal.
Some good suggestions here. I've got a few more problematic tooltips:
Face mark
currently
  • One Face Select feature edges if one of faces on the right and left has a face mark
  • Both Faces Select feature edges if both faces on the right and left faces have a face mark
my suggestion
  • One Face Select a feature edge if either of its adjacent faces is marked (or: has a face mark)
  • Both Faces Select a feature edge if both of its adjacent faces are marked (or: have a face mark)
Line style > Strokes
  • Chaining > Method (Chaining method) (or: method of jointing edges)
  • Caps (Shape of the stroke's ends)
Line style > Alpha
  • Alpha (Alpha transparency of the stroke) (following material transparency)
Tamito Kajiyama (kjym3) closed this task as Resolved.Apr 24 2014, 4:46 PM
Closed by commit rB95eb5fb72776.
Thank you all for nice suggestions.
Please, feel free to reopen the task when you find any other tool tips to revise.
