The problem with access to the site developer.blender.org #37458
legacy module
Rendering & Cycles
legacy module
legacy project
legacy project
Documentation
legacy project
Infrastructure: blender.org
legacy project
Infrastructure: Blender Web Assets
legacy project
Infrastructure: Websites
legacy project
Reference: infrastructure/blender-org#37458
The problem with access to the site developer.blender.org from my home computer.
IP address 46.219.7.222
Not even ping. From my work computer with a different IP it works.
Added subscriber: @cwolf3d
Added subscriber: @dmcgrath
Quite strange, all the Blender websites seem to have ip 82.94.226.* or 82.94.213.*.
@dmcgrath, any idea what could be going on here? Can it take a week to propagate DNS changes?
Looks like he landed on the firewall for hammering on the site. I removed the address, but please try to pace yourself in the future:)
Removed offending address from firewall on Thom
Again the same problem.
Or I quickly push or on my computer sits infection.
But on other sites okay.
Only developer.blender.org again blocked.
Long time blocked simply no longer wanted to bother.
Changed status from 'Resolved' to: 'Open'
Could you please describe how you are pushing with git, along with a rough estimate of time between commands? Now while you aren't the only person to have been blocked, it is a rare problem.
Also, you may wish to look into setting up get so that it pulls from one of the read only protocols like git:or http: which don't have as much of a restriction as SSH does for pushing. In other words, you can pull from one url and push to another in git.
PS - If you believe at all that your computer is infected with a virus, you should look into that ASAP.
As far as I can tell @cwolf3d doesn't have commit rights to any of the repositories, so I guess it wouldn't be from trying to push to those.
I was wondering why I couldn't see any commits from him either. I wonder why he said "Or I quickly push" then?
I guess we will just have to wait and see what @cwolf3d has to say about this.
Computer checked for viruses nothing suspicious found.
Since the last release just started to use the site.
Walk on it. And bam again stopped working completely.
Next time I will try to remember the time and place in which the site is a blocking call.
Well, if you were infected with something these days, chances are good that you wouldn't be able to detect it.
I am curious what you mean by "walk on it"? Do you mean that you are you crawling/saving the tracker? Because the rate that you would need to browse to get blacklisted is so high that mirroring the site is the only other way that I can think of that would hit the limits to get firewalled if you aren't using SSH.
Yes, I just looked different task. I did not load anything. Do not copy it. Nothing did. That and not use ssh.
Worked with the site via Opera. It was not a lot of open tabs.
Were opened http:*wiki.blender.org, http:*www.blender.org/documentation and http://developer.blender.org
Interested in what you need to do addon added to the official assembly.
Following links to any site http://developer.blender.org. So this link is not opened, blocked me.
Added subscriber: @pohjan
I have problems with developer.blender.org too. It gets 'Server not found error' with Elisa-laajakaista in Finland. With another internet prowider (Dna-mobile) I have no errors?
Other sub domains answers normally like wiki.blender.org and blender.org.
And I have tried make bug report with 3 different computer.
I still can access developer.blender.org using free proxyserver, but still tricky.
So, I quess dns - problems somewhere or is the ip-blocked somewhere?
@pohjan In order to unblock you, we would need to know the IP address used. It would also be nice to know what you were doing when this happened if you can please.
I have dynamic ip, it leased one of Elisa's pool. Last check it was 91.152.251.21
I have nat-server between local network and Internet, can this cause problems?
After blender site updates and moved to git. I worked about week. about two weeks ago I tried make Blender bug report and I noticed the developer.blender do not respond.
I guess the site is down, after that I go developer.blender site my friend home and noticed it working.
My home still does not. So I tested my mobile network (different provider) and it works.
@pohjan Unblocked the IP.
NAT wouldn't cause this, only connecting too many times in a short period of time gets you blocked. Best advice is to give a few seconds between git commands that pull via ssh, or browse web pages on developer.blender.org.
