Custom Prop Does Not Fire Update When Driven By F-Curve #37473
9 Participants
Reference: blender/blender#37473
Windows 7 x64 8GB
nVidia 460gtx 1GB
2.69 official release
My guess is that only a draw() event is being issued and not and update() behind the scenes.
custom_node_update_issue.zip
I have attached a custom node AddOn and a BLEND file that uses that AddOn.
Drop the AddOn into your AddOn folder and activate "test_node" under User Preferences. Then open the BLEND file.
You should see a series of three Float nodes.
Put Blender and the Console side by side so you can view the AddOn output.
The first node is animated. Scrub the Node Property Value directly to observe that the node does correctly send an update to all nodes downstream of it's output. It also generated print statements in the console as events are fired.
Scrub the Timeline and you will see that while the animated node and the next companion node do update, the third node does not. This is because the update=updateProperty def is not being fired when it is driven by an f-curve. This should happen. When I place a custom property under the object panel and animate it I do get an update event fired by the property. Also you will notice that not a single print statement is generated by the AddOn when you scrub the timeline even though the property value does change. This is the result of what I am calling a "fake" update event.
Theupdate() event of the node itself is not firing when you scrub the animation or render the animation via F12.
The only reason we see the second node update when we scrub the timeline is because there is some kind of special code in Blender that forces this "fake" update to only the first node connected. This "fake" update event should be removed from the system.
I know this is kind of a complex issue and please point out if my code is wrong. I hope this is enough info to describe the bug
Added subscriber: @AtomP
#95642 was marked as duplicate of this issue
#86675 was marked as duplicate of this issue
blender/blender-addons#48285 was marked as duplicate of this issue
blender/blender-addons#28286 was marked as duplicate of this issue
Added subscriber: @mont29
Assigning to Lukas to make the final decision, but I think this is a known limitation of our current depsgraph…
Added subscribers: @ideasman42, @dfelinto, @JoshuaLeung, @brecht, @Ton
◀ Merged tasks: blender/blender-addons#28286.
Indeed this is a general limitation of the animation system: it doesn't execute update callbacks of properties. This has been discussed several times, but doesn't look like it's simple to implement, mostly because it would add overhead and slow down animation playback significantly (see duplicates and blog post by Joshua )
For your specific case i would suggest using a frame update handler and do an evaluation of the node tree data there. Using update callbacks for evaluating nodes is generally not the best way to handle it, they are intended for handling updates locally.
Added subscriber: @kpghost
It's been a while since this bug was opened. Is using a frame update handler (as mentioned by lukastoenne) still the recommended way to process updates to custom properties while animating? Or is there a better/simpler way now?
The situation here has not changed, as far as I know.
Added subscriber: @JulienDuroure
Added subscriber: @StanislasPaillereau
Added subscribers: @dodododorian, @lichtwerk, @JaumeBellet
Added subscriber: @karab44
