Crash making linked objects local and undo #37599
Closed
opened 2013-11-24 15:01:58 +01:00 by richie967 · 18 comments
richie967 commented 2013-11-24 15:01:58 +01:00 (Migrated from localhost:3001)
Dell Studio 1749, i3, Windows 7, 1 GB ATI Mobility Radeon HD 5650
Broken: Blender 2.69.0 r60995
Steps to Redo
when importing the attached blender file objects into a new blender file, using file > link, linking just the objects, then make all objects local, then move up, move down, then as soon as i click 'ctrl & z' the blender crashes,
Any ideas?
undo steps set to 32
coffee-table3.blend
**System Information** Dell Studio 1749, i3, Windows 7, 1 GB ATI Mobility Radeon HD 5650 **Blender Version** Broken: Blender 2.69.0 r60995 **Steps to Redo** when importing the attached blender file objects into a new blender file, using file > link, linking just the objects, then make all objects local, then move up, move down, then as soon as i click 'ctrl & z' the blender crashes, Any ideas? undo steps set to 32 [coffee-table3.blend](https://archive.blender.org/developer/F32136/coffee-table3.blend)
Author
#39354 was marked as duplicate of this issue
richie967 commented 2013-11-24 15:01:59 +01:00 (Migrated from localhost:3001)
Author
Author
Added subscriber: @richie967
Added subscriber: @brecht
Please add all the requested information about system information, blender version, steps to redo, etc, not just a title.
richie967 commented 2013-11-24 15:24:38 +01:00 (Migrated from localhost:3001)
Author
Hi brecht,
here is some more information....
Any ideas?
undo steps set to 32{F32136}
Hi brecht, here is some more information.... System Information Dell Studio 1749, i3, Windows 7, 1 GB ATI Mobility Radeon HD 5650 Blender Version Broken: Blender 2.69.0 r60995 when importing the attached blender file objects into a new blender file, using file > link, linking just the objects, then make all objects local, then move up, move down, then as soon as i click 'ctrl & z' the blender crashes, Any ideas? undo steps set to 32{[F32136](https://archive.blender.org/developer/F32136/coffee-table3.blend)}
Brecht Van Lommel changed title from blender crashes when doing an undo 'ctrl & z'... This happens shortly after linking in an object, making it local ,moving it around, then pressing undo to Crash making linked objects local and undo 2013-11-25 20:29:45 +01:00
I can confirm the crash with the above steps, linking in all objects in this file.
Sergey Sharybin self-assigned this 2014-02-17 10:11:18 +01:00
@brecht, i couldn't really reproduce the crash. Do have:
Warning: LIB ERROR: object lost from scene: 'Scene'
messages in the console after the undo tho. Will have a look into this issue, but wouldn't mind having some details about crash..
@brecht, i couldn't really reproduce the crash. Do have: ``` Warning: LIB ERROR: object lost from scene: 'Scene' LIB ERROR: object lost from scene: 'Scene' ``` messages in the console after the undo tho. Will have a look into this issue, but wouldn't mind having some details about crash..
thread #25: tid = 0x14d564, 0x0000000100aeb4d1 blender`BKE_curve_bevel_make(scene=0x0000000106501008, ob=0x00000001065e1c08, disp=0x0000000115f4bcb8, forRender=0, renderResolution=0) + 161 at curve.c:1641, stop reason = EXC_BAD_ACCESS (code=1, address=0x114)
  frame #0: 0x0000000100aeb4d1 blender`BKE_curve_bevel_make(scene=0x0000000106501008, ob=0x00000001065e1c08, disp=0x0000000115f4bcb8, forRender=0, renderResolution=0) + 161 at curve.c:1641
  frame #1: 0x0000000100b0fe08 blender`do_makeDispListCurveTypes(scene=0x0000000106501008, ob=0x00000001065e1c08, dispbase=0x000000010563da88, derivedFinal=0x00000001065e2120, forRender=0, forOrco=0, renderResolution=0) + 552 at displist.c:1396
  frame #2: 0x0000000100b0fbce blender`BKE_displist_make_curveTypes(scene=0x0000000106501008, ob=0x00000001065e1c08, forOrco=0) + 222 at displist.c:1612
  frame #3: 0x0000000100bf1224 blender`BKE_object_handle_update_ex(eval_ctx=0x000000010563f898, scene=0x0000000106501008, ob=0x00000001065e1c08, rbw=0x0000000000000000) + 1508 at object.c:2945
  frame #4: 0x0000000100c4924d blender`scene_update_object_func(pool=0x0000000113ad2128, taskdata=0x0000000113aabc98, threadid=6) + 285 at scene.c:1320
  frame #5: 0x0000000100dcf2b8 blender`task_scheduler_thread_run(thread_p=0x0000000105721098) + 104 at task.c:137
  frame #6: 0x00007fff85424899 libsystem_pthread.dylib`_pthread_body + 138
  frame #7: 0x00007fff8542472a libsystem_pthread.dylib`_pthread_start + 137
  frame #8: 0x00007fff85428fc9 libsystem_pthread.dylib`thread_start + 13
cu->bevobj->data and so bevcu is NULL. It's easy to add a NULL check but that doesn't seem like the right solution.
It should be possible to reproduce this if you follow these steps:
  • New file
  • File > Link, go to Objects, press A to select all, click Link
  • L key to make local > Selected Objects
  • G key to move, enter to confirm.
  • Ctrl + Z to undo
``` thread #25: tid = 0x14d564, 0x0000000100aeb4d1 blender`BKE_curve_bevel_make(scene=0x0000000106501008, ob=0x00000001065e1c08, disp=0x0000000115f4bcb8, forRender=0, renderResolution=0) + 161 at curve.c:1641, stop reason = EXC_BAD_ACCESS (code=1, address=0x114) frame #0: 0x0000000100aeb4d1 blender`BKE_curve_bevel_make(scene=0x0000000106501008, ob=0x00000001065e1c08, disp=0x0000000115f4bcb8, forRender=0, renderResolution=0) + 161 at curve.c:1641 frame #1: 0x0000000100b0fe08 blender`do_makeDispListCurveTypes(scene=0x0000000106501008, ob=0x00000001065e1c08, dispbase=0x000000010563da88, derivedFinal=0x00000001065e2120, forRender=0, forOrco=0, renderResolution=0) + 552 at displist.c:1396 frame #2: 0x0000000100b0fbce blender`BKE_displist_make_curveTypes(scene=0x0000000106501008, ob=0x00000001065e1c08, forOrco=0) + 222 at displist.c:1612 frame #3: 0x0000000100bf1224 blender`BKE_object_handle_update_ex(eval_ctx=0x000000010563f898, scene=0x0000000106501008, ob=0x00000001065e1c08, rbw=0x0000000000000000) + 1508 at object.c:2945 frame #4: 0x0000000100c4924d blender`scene_update_object_func(pool=0x0000000113ad2128, taskdata=0x0000000113aabc98, threadid=6) + 285 at scene.c:1320 frame #5: 0x0000000100dcf2b8 blender`task_scheduler_thread_run(thread_p=0x0000000105721098) + 104 at task.c:137 frame #6: 0x00007fff85424899 libsystem_pthread.dylib`_pthread_body + 138 frame #7: 0x00007fff8542472a libsystem_pthread.dylib`_pthread_start + 137 frame #8: 0x00007fff85428fc9 libsystem_pthread.dylib`thread_start + 13 ``` `cu->bevobj->data` and so `bevcu` is NULL. It's easy to add a NULL check but that doesn't seem like the right solution. It should be possible to reproduce this if you follow these steps: * New file * File > Link, go to Objects, press A to select all, click Link * L key to make local > Selected Objects * G key to move, enter to confirm. * Ctrl + Z to undo
@brecht, managed to reproduce now. Checking for NULL is not the right solution at all, we need to understand why object data is got lost.
@brecht, the issue is actually caused by linked curve pointing to a local object which screws up the file loading. As far as i can tell it's not really supported situation so guess proper solution would be to disallow making IDs local if they're used by other datablocks?
Right, either that or making the other datablocks local automatically, but to me it seems better to refuse and let the user then use Selected Objects & Data. So yes, I think we should disallow it.
Added subscriber: @koilz
◀ Merged tasks: #39354.
Author
This issue was referenced by blender/blender-addons-contrib@6e5e3b73f3
This issue was referenced by blender/blender-addons-contrib@6e5e3b73f37f952420d87a3d8acd07a7f68dd5a3
Author
This issue was referenced by 6e5e3b73f3
This issue was referenced by 6e5e3b73f37f952420d87a3d8acd07a7f68dd5a3
Closed by commit 6e5e3b73f3.
Reference: blender/blender#37599
