Segfault on Ctrl+T
gentoo ~amd64 gtx660m (asus g75vw)
Broken: Blender last git
Worked: Blender 2.69 release
Segfault (blender crash) triangulate on Ctrl+T, but all right when i do it with select in menu "Triangulate face"
To check error, please do Ctrl+T on default cube's face
Could not reproduce here.
@Campbell Barton (campbellbarton), do you remember maybe there were fixes from you in this area?
after update blender i still get segfault
Brecht Van Lommel (brecht) triaged this task as Normal priority.Nov 26 2013, 3:39 PM
@brothermechanic (brothermechanic) - cant redo this bug. we need some way to redo so we can fix.
Campbell Barton (campbellbarton) lowered the priority of this task from Normal to Needs Information from User.Nov 26 2013, 8:45 PM
If you didn't already, can you test a recent build from here:
http://builder.blender.org/download/
If you are making your own build, did you set any special optimization flags or build options? Maybe you're using a newer compiler or building in some special environment.
Brecht, THANK YOU! now it works good!
I think @Campbell Barton (campbellbarton) actually fixed this one. Thanks for the report, closing.
