Indirect lighting does not observe hidden layers correctly #37723
2 Participants
Reference: blender/blender#37723
x86_64 Linux Mint 15, kernel version 3.8.0-19
nVidia GTX 650 Ti graphics, driver version 310.44
Broken: Blender 2.66 - 2.69
Worked: Unknown
Rather than using layers which are visible during the render, indirect lighting will instead use layers which are visible to the viewport. So, if you have mesh objects on layer 1 and a lamp on layer 2, and hide layer 2 from the render, then it will still use lights from layer 2. The same goes for objects: if an object is on a layer which is hidden from render and not hidden from the viewport, then it will use that object to calculate indirect lighting as well.
Added subscriber: @ZauberParacelsus
I've uploaded a second blend file, which adds a light to the scene. You'll see that indirect light from the lamp is visible, while direct light is not.
IndirectLightingBug2.blend
It's by design, what you call "viewport layers" are the "scene layers" in the render layer properties.
http://wiki.blender.org/index.php/Doc:2.6/Manual/Render/Cycles/Passes#Layers
So, is there no way to completely hide an object or lamp from rendering while at the same time leaving it visible in the viewport?
In the 3D view header, on the right of the layer buttons there is a button to decouple the 3D view layers from the scene layers.
Thanks, that appears to do the trick.
