UV Utility Addon
Hello guys!
I did UV Utility Addon.
Features:
  • Move UVMap Indexes. This is very important for game engines (Unity, Unreal, Ogre3d...). As they use UVTexCoord1, UVTexCoord2.. No names at all.
  • Select UVMaps by Index or by Name and set them active/render_active.
  • Remove active UVMaps.
All Features are for selected objects only.
Here is a small demonstration:
http://www.youtube.com/watch?v=FnFx4WXJbCI&feature=youtu.be
The script:
https://blender-addons-by-mifth.googlecode.com/hg/uv/uv_utility.py
Thanks.
paul geraskin (mifth) added a project: Addons.
paul geraskin (mifth) set Type to Patch.
paul geraskin (mifth) created this task.
paul geraskin (mifth) raised the priority of this task from to Needs Triage by Developer.
Having a toolbar for quick UV access could be handy, though being able to move uv layers up/down seems like it should be added into Blender rather then having as an addon. (seems more like a workaround).
Id like to look into this.
The other addon functionality seems OK, but also like we could improve existing UI a bit to remove the need for it.
I guess you say about this toolbar for blender? http://i.imgur.com/MbsBh2l.png
But the feature of the addon is that you can select 1000 objects and move/setActive UVMap index for all of them just with one click.
mifth, ah, I see, yep - re-ordering many UV's at once cant be done even if those buttons are added.
It seems like this addon has been removed from Blender. Also I can't get it to work even after downloading and installing it from github.
https://github.com/sambler/myblendercontrib/blob/master/uv_utility.py
Hi,
I see uvutility in repository.
https://developer.blender.org/diffusion/BAC/
Possibly, you misunderstood something about the repository?
What kind of error do you have. Give me the log of the error.
