OpenCL Compositing Bug #37832
10 Participants
Reference: blender/blender#37832
{F41577}System Information
Windows 7 Professional x64, nVidia Geforce GTX 660
Broken: Blender 2.69 r60995, daily buid 2.69-740c7e6
Worked: Don't Know
On rendering any scene using the "Defocus" node some parts of the image that should be blurred aren't when OpenCL is checked{F41623}.
Just hit render.
Added subscriber: @Paul.Brachmann
Added subscribers: @Jeroen-Bakker, @monique
Added subscriber: @maxint
Added subscriber: @cdog
Hi paulb
Just some questions and checks:
Best regards,
Jeroen
Hi jbakker
Thanks for your interest.
One last thing: What's really strange is that when I recompose (shortcut: c) it sometimes works as expected and sometimes not (without changing anything in the scene or node-setup).
Added subscribers: @LukasTonne, @Sergey
@LukasTonne, maybe you've got clues here?
Might be related to #38011, at least this skipping of later chunks (when starting in the middle) seems to indicate that. I think we have a problem in the compo scheduler ...
@Paul.Brachmann could you make a test file and attach it here? Neither @Sergey nor i could reproduce this bug so far.
I think I actually did upload the test file with the original description but here is it (again).
Thanks. I still can't reproduce the error with that file, but i did get a couple of OpenCL error messages (can't tie them to anything specific):
This looks to me as if the OpenCL device is running out of memory, but i have to investigate this more. Given that i also have a GTX 660 this is a bit strange.
Hi @LukasTonne,
as far as I know there are different memmory configurations of the GTX 660 available.
You may have a different one than I have. I also mentioned that sometimes it works and sometimes not.
I don't know why this happens but it could be that you just had (bad-)luck an it worked.
I actually also encountered this bug. I have an AMD Radeon HD 6500M/5600/5700 Series . I suspect the defocus node is the cause, because it occurred when I used it. But it's not easily reproducible. I rendered an animation and most of the frames were fine, but several had this exact error.
Added subscriber: @MichaelParucha
I can also reproduce the error (Windows 7 64bit, NVIDIA GeForce GTX 760 2 GB, latest driver).
Managed to reproduce using NVidia video card on windows. Seems i'm the only one developer wjo managed to reproduce it so assiginig to self :)
The culprit is here:
https://developer.blender.org/diffusion/B/browse/master/source/blender/compositor/operations/COM_VariableSizeBokehBlurOperation.cpp;7aa86ec243f92cee6f5de040f989fc7779f0e5a1$200
The
sizeMemoryBuffer
doesn't seem to be fully defined, it returns bogus values for the chunks in question, which leads to invalid results of thedefocusKernel
OpenCL code.Have been trying all day to get my head around how the synchronization between OpenCL and CPU work packages is achieved, but this is really confusing code ...
Re-assigning to @Jeroen-Bakker, hopefully he'll have more clues here.
@Jeroen-Bakker, found any time to look into this?
Added subscriber: @mano-wii
This bug is intriguing. It seems simple. But no one solved in 2 years
Edit: In the latest builds seems to have been SOLVED.
Edit2: No, now the image resolution must be 3840x2160 for the problem to can be seen.
Just for the clarity.
I would take effort to fix this, if I can reproduce it on one of my machines.
Quite frustrating to see that this still isn't resolved. @Sergey, maybe you could have another look as Jeroen isn't able to recreate?
