Disable tooltip scaling with UI zoom levels #37917
5 Participants
Reference: blender/blender#37917
Currently when you zoom out in the node view or in the properties editor, the tooltip zooms too, when zooming out especially this is not so useful.
However there is some value in showing larger tooltips when zooming in (since you might zoom in to look closer at the UI).
Even so, if you have trouble reading tips and the default zoom level you should set the DPI higher.
Proposing to use the same tooltip size no matter what zoom level is used in the interface.
Added subscriber: @ideasman42
Added subscriber: @JonathanWilliamson
Yes, that's silly to zoom the tooltips. Using the same global scale would be much better.
Added subscriber: @billrey
@ideasman42: Agreed, makes sense.
I think the use-case for zooming in/out is to focus on a couple of nodes or get an overview, not looking at the UI.
This issue was referenced by blender/blender-addons-contrib@7294c54db0
7294c54db0
Closed by commit
7294c54db0
.Note, left this behavior when zooming in, it looked odd to show tips smaller then surrounding text.
Added subscriber: @heijulien
I just discovered this and wanted to add that it also looks odd when it is larger than the surrounding editor text. Maybe it should use a constrained range (if at all, i'd prefer it kept the same level)
