Add missing 'New' button to Particle properties #37998
Reference: blender/blender#37998
The issue
Blender's datablock system has a consistent way to add new items, except for Particles, which is missing the 'New' button. Users can manually add a particle channel and create a particle system that way, but it's inconsistent with materials, which presents a large New button, even when there are no material channels.
It's a smaller issue, but inconsistencies like these add up to create unneeded confusion.
In Materials, you get this when there are no channels:
In Particles, you get this. Notice the lack of a New button:
Proposed solution
Add the missing 'New' button inside Particles properties, like so:
Advantages
Added subscriber: @billrey
Added subscribers: @JonathanWilliamson, @brecht
Agree, we should have this.
Hi I would like to have a go at coding this if no one else objects...
Sure, go ahead.
Agreed this is needed. I might even suggest taking it a bit further and making the slot behavior for particles be the same as materials. For example, the behavior when pressing the + button.
In materials the + adds a slot. In particles it adds a new particle system, making it impossible to add a new empty slot (because you may want to use an existing particle system).
OK, had a look at this (and learnt a lot along the way...)
caveat: this is the first lot of serious programming I've done in 15 years and so I may make a few stupid statements along the way...
IMHO:
It's not as easy as it looks as by default when Blender opens there is a material and a texture for the cube and so there are values for object.active_material and object.active_material.active_texture which which are used by the Materials context and Texture context to pass to the 'C' Template_ID() function which then triggers the relevant draw functions depending on what information has been passed.
The same does not exist for Particle Systems. You can access object.particle_systems.active but if particle_systems = None then Template_ID() throws an error as the .active part does not have a valid pointer (i.e. there is nothing for it to work with).
BTW: The same error occurs if you try to access object.current_material.current_texture when you have deleted all materials. The texture context UI handles this situation by removing the material button above the texture list until at least one material slot has a material so a user cannot cause this error to occur.
Even though object.particle_systems = None, if you try to pass object.particle_systems to Template_ID() it errors as this is all the particle systems linked to the object (a "collection") not an individual particle system. Template_ID does not like collections...
So Options:
Live with it as it is today...
Simplest way is to extend the Python API to create object.active_particle_system and which would return the active particle system name or None if there aren't any. A few small changes in the properties_particles.py and some doc update. This may take me a while as it will be all new ground...
Go with Jonathan's suggestion and implement particle slots. Off the top of my head I think would involve multiple Python API changes; larger changes to properties_particle.py; much doc update; updating the startup.blend file to have one empty slot to begin with and many other things that I'm sure will will jump up and bite me... ;)
Mess around with Template_ID() so it can handle collections being passed to it that = None. I really think this is a bad idea as there would be a high potential to break something and tries to shove too much into one function...
I think #2 would be a good start but happy to give #3 a go if that is what we want...
OK - further discoveries starting with a wrong tool tip.
This should read Browse Particle Settings to be linked. Brecht I have submitted a .diff this morning to fix this. I believe it is in the right format this time.
Moving on... I think some of the confusion may be coming from assuming the IDBlock browser/editor for the particle settings relates to the UI list with the particle systems. As in:
If we were to follow the same setup as a material then it should look like this when you have created a particle system and a particle settings... perhaps a way to think of it is a particle system is like a material that can have only one texture (the particle settings)...
An alternative is to have this:
I think we should avoid setting it up so that when there are no particle systems that the IDblock browser/editor is to create a Particle System and when one is created the IDBlock browser/editor changes to Particle Settings... which is basically what was proposed initially by William.
In any option I still have to get the IDBlock browser/editor working for the Particle Systems (I don't think it exists at the moment) so I'll keep working on that...
Particles systems are not ID blocks and should not have an ID block browser. They can't be shared between objects so it doesn't make sense to choose them, you only have a list of them on an object.
The way I imagined this working is that you would have a object.active_particle_settings property, that when you set it to a value and there is no particle system, it creates a particle system, the same way it creates a material slot when you assign a material. It wouldn't be an actual property in the C struct, rather just an RNA property with get/set function that reads from or creates particle systems.
About @JonathanWilliamson's suggestion of creating an empty particle system when you press (+), we could do this but I think it would cause some user confusion and implementation difficulties. An empty material slot works ok but an empty particle system is problematic, it's much more than just a slot and doesn't function without one.
@brecht:
Hmm.. You can share particle systems between objects. If you create a particle system called 'Fu' on Object A, you can pick the same 'Fu' particle system in Object B.
The confusing thing is that the name of the particle system is not reflected in the Particle system slot list. It currently works different from materials where the name of the material is reflected in the slot list too.
I think we should simplify this, at make particles work like materials. There's no need to be able to rename slots different than particle system data.
No, those are particle settings.
Some things can be shared, but edited hair, vertex groups, point cache, seed and a few other things are part of the particle system only, not the particle settings. So you can have the same particle settings multiple times on one object in different variations.
@brecht: Ok, so it's like half the stuff in Particles it attached to the particle 'datablock', but the other half it attached directly to the object data?
That's pretty confusing :)
Anyway, we could solve it by removing the 'Name' field (Now we have the ability to rename via double click directly in lists), and then just putting the 'Settings' field underneath with a New button, like so:
Hi,
Need to work out why it is totally Disabled...
You can't delete Particle Settings because a Particle System can't work without them, and generally datablocks don't have a delete button, only an unlink button.
OK, spent some time on the weekend trying to un-disable the particle setting ID Browser without any success. I suspect that until a particle system exists on the object particle settings will be disabled. Clearly the two are very closely linked and you can't really create/delete one without the other.
So, rather than spend more time chasing my tail here is a solution:
Unlike William's mock-up it doesn't have the particle setting browser icon on the the left of the button. In a way just having the New button is really correct as you aren't adding particle settings - you are adding a particle system (as per the tooltip). I have checked that the translations are working as well.
I don't think we are going to get much better than this in the short term, so I'll submit a .diff for this change.
