KX_PolyProxy has incorrect getVertexIndex results #38030
Closed
opened 2014-01-02 16:32:50 +01:00 by Angus Hollands · 17 comments
This is a serious flaw in the API, which has occurred somewhere between Blender 2.64 and HEAD.
The values from getVertexIndex are (I believe) per bucket, which isn't respected in the getVertex call. I'm not sure whether the issue is in RAS_MeshObject or whether it is before this point, but essentially calling offset = slot->AddVertex(texvert) returns the bucket vertex index
This is a serious flaw in the API, which has occurred somewhere between Blender 2.64 and HEAD. The values from getVertexIndex are (I believe) per bucket, which isn't respected in the getVertex call. I'm not sure whether the issue is in RAS_MeshObject or whether it is before this point, but essentially calling offset = slot->AddVertex(texvert) returns the bucket vertex index
Author
Author
Added subscriber: @AngusHollands-4
Author
Revision: dee33e8097
Author: Campbell Barton ideasman42@gmail.com
Date: 01/05/2013 23:41:55
Message:
fix [#34609] mesh.getVertex doesn't work as spected with poly.getMaterialIndex() and poly vertex indexes
revert r22906 (own old commit, was incorrectly trying to make vertex indices absolute)
Modified: source/gameengine/Ketsji/KX_PolyProxy.cpp
Modified: source/gameengine/Rasterizer/RAS_Polygon.cpp
Modified: source/gameengine/Rasterizer/RAS_Polygon.h
This seems to be the culprit
Revision: dee33e80970ff0b83a06b2dd5d23b8e25f7317df Author: Campbell Barton <ideasman42@gmail.com> Date: 01/05/2013 23:41:55 Message: fix [#34609] mesh.getVertex doesn't work as spected with poly.getMaterialIndex() and poly vertex indexes revert r22906 (own old commit, was incorrectly trying to make vertex indices absolute) ---- Modified: source/gameengine/Ketsji/KX_PolyProxy.cpp Modified: source/gameengine/Rasterizer/RAS_Polygon.cpp Modified: source/gameengine/Rasterizer/RAS_Polygon.h This seems to be the culprit
"Unbreak now" is only meant for Release show stoppers.
Author
My apologies, I had intended to set to medium.
Inês Almeida self-assigned this 2014-06-21 00:13:57 +02:00
Member
@AngusHollands-4 I am not sure I understand the problem.
The documentation says this:
"Returns the mesh vertex index of a polygon vertex This index and the one returned by getMaterialIndex() are needed to retrieve the vertex proxy from MeshProxy."
The commit dee33e8097 is already correcting something, are you saying it has a bug or that it is supposed to do something different?
I really don't know what this does or is supposed to do.
@AngusHollands-4 I am not sure I understand the problem. The documentation says this: "Returns the mesh vertex index of a polygon vertex This index and the one returned by getMaterialIndex() are needed to retrieve the vertex proxy from MeshProxy." The commit dee33e8097 is already correcting something, are you saying it has a bug or that it is supposed to do something different? I really don't know what this does or is supposed to do.
Author
Originally, the commit by Campbell appeared to break things. Since then the issue has disappeared, so I think this can be closed!
Member
great! :)
great! :)
Member
Changed status from 'Resolved' to: 'Open'
Added subscriber: @Pickledtezcat
I'm having trouble with this still, with Blender 2.72b (and before). Rather than open a new bug I'm going to reopen this one as it seems to be the same problem that never went away.
Some more details:
When using
poly = mesh.getPolygon(polyID)
        vert_length = poly.getNumVertex()
        for v in range(vert_length):
            index = poly.getVertexIndex(v)
            vertex = mesh.getVertex(0, index)   ### (the material index is 0 since there's only one material on the object).
The getVertexIndex() call is getting the wrong index in the following situations:
  1. when you have a mix of quads and triangles in a mesh.
  2. when you have more than one material in a mesh.
For illustration I've used a property to store xyz co-ordinates in poly groups captured from the mesh and then render.drawline to illustrate the results. You can see that all quad meshes and all triangle meshes are fine, but everything else just returns the wrong indexes. The objects are the same, just with some quads triangulated.
You can recreate the bug using this Blend:
poly_problems.blend
Just run the game engine.
In a nutshell the problem is that the poly.getVertexIndex as well as the poly.v1 poly.v2 poly.v3 poly.v4 functions (I tested them too with the same result) to return constituent vertices of a polygon are broken. They only work when all polys are of one type, either quads or triangles and only one material is present.
I'm having trouble with this still, with Blender 2.72b (and before). Rather than open a new bug I'm going to reopen this one as it seems to be the same problem that never went away. Some more details: When using ``` poly = mesh.getPolygon(polyID) vert_length = poly.getNumVertex() for v in range(vert_length): index = poly.getVertexIndex(v) vertex = mesh.getVertex(0, index) ### (the material index is 0 since there's only one material on the object). ``` The getVertexIndex() call is getting the wrong index in the following situations: 1. when you have a mix of quads and triangles in a mesh. 2. when you have more than one material in a mesh. ![poly_problems_2.jpg](https://archive.blender.org/developer/F122066/poly_problems_2.jpg) For illustration I've used a property to store xyz co-ordinates in poly groups captured from the mesh and then render.drawline to illustrate the results. You can see that all quad meshes and all triangle meshes are fine, but everything else just returns the wrong indexes. The objects are the same, just with some quads triangulated. You can recreate the bug using this Blend: [poly_problems.blend](https://archive.blender.org/developer/F122068/poly_problems.blend) Just run the game engine. In a nutshell the problem is that the poly.getVertexIndex as well as the poly.v1 poly.v2 poly.v3 poly.v4 functions (I tested them too with the same result) to return constituent vertices of a polygon are broken. They only work when all polys are of one type, either quads or triangles and only one material is present.
Added subscriber: @JacobMerrill-1
Member
Added subscriber: @JorgeBernalMartinez
This issue was referenced by 2a305580b2
This issue was referenced by 2a305580b2c76af62c129fbca043466ab010c2df
8 Participants
Reference: blender/blender#38030
