Right click in Particle Edit mode closes application
Windows 7 Ultimate 64 bit and Nvidia GeForce GTX 480
Broken: 2.69.0 r60995
  1. Create Plane.
  2. Add Particle System and Bake without any additional settings.
  3. Go to Particle Edit mode and switch to Tip Select mode.
  4. Try selecting a particle tip with right mouse button (The application crashes)
Based on a (as simple as possible) attached .blend file with minimum amount of steps:
http://dox.bg/files/dw?a=5ca48e5a3c
Rumen Belev (syziph) set Type to Bug.
Rumen Belev (syziph) created this task.
Rumen Belev (syziph) raised the priority of this task from to Needs Triage by Developer.
I cannot confirm this problem based on the given steps.
Using the provided .blend I get a crash as well.
My system:
Windows 7 Professional x64, nVidia GeForce GTX 660
Sergey Sharybin (sergey) triaged this task as Confirmed, Medium priority.
