DXF Import Addon
Improvements to the existing addon: Splines and arcs get imported as bezier curves. Blocks get imported.
It uses dxfgrabber as a library. So far I tested only text-based DXF files.
It converts:
  • splines, arcs and polylines with bulges to bezier curves
  • blocks to linked objects
  • layers to groups
Blocks within another block get imported as objects that are parented to the outer block.
Everything gets imported as curves. No options.
Lukas Treyer (cnd) added a project: Add-ons.
Lukas Treyer (cnd) set Type to Patch.
Lukas Treyer (cnd) created this task.
Lukas Treyer (cnd) raised the priority of this task from to Needs Triage by Developer.
Brecht Van Lommel (brecht) triaged this task as Normal priority.Jan 22 2014, 1:57 PM
Brendon Murphy (meta-androcto) closed this task as Archived.
closing as archived, there's activity in the addon past the date of this addon, if this task is still valid, please update with a new fresh task.
https://developer.blender.org/diffusion/BA/browse/master/io_import_dxf/
