Segmentation fault, when script active and render animation with motion blur
osx 10.9.1, mbpr 13.1, 16gb Ram
Broken: own 2.69.10 a81cf31 and buildbot e07e8e3
Worked: official 2.69
Blender crash on random frame while rendering animation. Sometimes it crashes after 30 frames sometimes after 1. It appears only to happen if Motion Blur is enabled.
  File "/Text", line 9, in update_test
  File "/Text", line 37, in focus_test
AttributeError: Writing to ID classes in this context is not allowed: Camera, Camera datablock, error setting Camera.lens
Segmentation fault: 11
Open crash.blend
Run the Script
Hit Render Animation
The Auto Tile Size Addon suffers the same issue - if you animate the render tile size it crashes blender eventually:
  File "/Users/bashi/Library/Application Support/Blender/2.69/scripts/addons/auto_tile_size_release_02.py", line 65, in on_scene_update
    scene.TileSizePrevDevice = device
AttributeError: Writing to ID classes in this context is not allowed: Scene, Scene datablock, error setting Scene.TileSizePrevDevice
trigger device changed
Sergey Sharybin (sergey) triaged this task as Confirmed, Medium priority.
You have a classical race condition - update() called from UI thread, update_test() called from render animation thread on the same time.
Write access to bpy.context.scene.camera.data.lens (or any other property in general) be in need of properly locking.
But I have no idea how to implement it correctly.
