New TABs on T panel, PINS
OSX 10.8.5, ATI HD 5870
Latest builbot OSX builds
PIN TABS, shift+click unpins TABS, ctrl+click is broken or does the same as shift+click.
CTRL+Click should work as before. Or as under Properties panel.
Brecht Van Lommel (brecht) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Feb 4 2014, 2:51 PM
What is the exact Blender version you are using (as found in the top right of the splash screen)? Is it 6a2c467?
It works fine for me in that build, ctrl+click behaves as in the properties editor and shift+click pins. Where in the panel header are you ctrl+clicking, on the name, on the location of the pin icon, .. ?
yes, it is 6a2c467 OSX
I can pin by shift clicking, I can un pin by shift clicking (or by RMB)
But if I ctrl+click this unpins everything, Ctrl+click should function differently. Now it works like shift click on pinned elements.
Obviously it is a bug.
Also checked on linux and windows builds.
