Operating system: Win xp sp3
Graphics card: Ati radeon HD 5400
Blender Version: 2.69.7 60995
Aim:
Create a beveled or round edge of exact 5mm radius.
Bevel works exact with edges between 2 faces with the same dimensions. But if the dimension of faces is different problems come out.
Exact steps for others to reproduce the problem
**Ref to attached file
http://oi58.tinypic.com/rs4sqd.jpg:**- Insert a cube
- Enter edit mode pressing TAB
- Select an edge
- Press Ctrl+B
- By the keyboard insert 0.05. This is the bevel radius (similar to autocad)
This works correctly and generates a correct beveled edge with the 45° angle, as needed:
http://oi61.tinypic.com/2vjabsg.jpg:**- Insert a cube
- Scale the cube on z axis only untill obtained a 2*2*0.1 mesh
- Select an edge
- Press Ctrl+B
This does not work correctly and generates strange beveled edges without the correct 45° angle needed. The angle of the resulting beveled edge is different depending on the dimensions of the two faces dimensions that meet at the beveled edge. so the bevel result is almost inexistent:
**See the yellow edge into the attached files
http://oi58.tinypic.com/rs4sqd.jpg and compare with the other attached file http://oi61.tinypic.com/2vjabsg.jpg.**As you can see the angle is not of 45° in the second mesh.
