Crash: load new level; array modifier using curve length #38553
Reference: blender/blender#38553
Ubuntu 13.10, 64-bit; I think it happens on Windows too.
AMD Mobility Radeon HD 5430
Broken: 2.69
a7b1349
(31 Jan),4393398
, b105d2aWorked: 2.69
7294c54
(23 Dec)Short description of error
If a game loads a file that contains an object with an array modifier that uses a curve to set its length, blender/blenderplayer will segfault.
bge_loader.blend
P
The game will start and immediately load
bge_curve_array_crash.blend
. At that point, it will crash with this stack trace:bge_curve_array_backtrace.txt
It seems that
amd->curve_ob->curve_cache
isnull
.If you start the game from
(which contains the array object), it does not crash.Changed status to: 'Open'
Added subscriber: @z0r
I ran a
git bisect
; it seems the first bad version isac077f016d
. Full log:bge_curve_bisect.txt
Added subscriber: @Sergey
@Sergey, what do you think about this? To fix this, we could revert
ac077f0
apart from the DAG node tagging part - but then we're back to needing a reference to the scene.Would need to look further into this issue. All the stuff which is related on object evaluation should happen strictly in order defined in DAG and there should no be any
if(data_is_not_ready) { prepare_data; }
things.But found some more cases when following this rule crashes. Will either find some proper solution or temporary revert the change or until proper solution is ready.
This issue was referenced by blender/blender-addons-contrib@c0a13322cd
c0a13322cd
Closed by commit
c0a13322cd
.Thank you, Sergey! Fix confirmed.
