Linking a group fails when you choose Append, but enable Link in the options. #38695
Closed
opened 2014-02-18 06:00:40 +01:00 by Andrew Price · 14 comments
Windows 7, Nvidia GTX 660
Broken: Blender 2.69.6dafb89 (latest build)
Worked: Has been a bug for as long as I can recall.
Linking a group into the .blend fails, then once failed you can never append or link that group into the .blend ever again.
This only happens when you choose Append from menu, but check Link in the toolbar.
  1. Open the default scene
  2. With the cube select press Ctrl+G to make a group.
  3. Save the blend file
  4. Start a new blend file
  5. Press Shift+F1, locate the .blend, and select the group.
  6. Check the box in the toolbar that says Link.
  7. Click Link.
  8. You should notice that the group has not been appended to the file, nor has an error been displayed (nothing in console either).
  9. If you now try to Append that same group it won't work either.
This causes big problems when you've got a scene that requires a certain group to be appended. But once this mistake is made there's no way to go back. You can never append that group into the .blend.
**System Information** Windows 7, Nvidia GTX 660 **Blender Version** Broken: Blender 2.69.6dafb89 (latest build) Worked: Has been a bug for as long as I can recall. **Short description of error** Linking a group into the .blend fails, then once failed you can never append or link that group into the .blend ever again. This only happens when you choose Append from menu, but check Link in the toolbar. **Exact steps for others to reproduce the error** 1. Open the default scene 2. With the cube select press Ctrl+G to make a group. 3. Save the blend file 4. Start a new blend file 5. Press Shift+F1, locate the .blend, and select the group. 6. Check the box in the toolbar that says Link. 7. Click Link. 8. You should notice that the group has not been appended to the file, nor has an error been displayed (nothing in console either). 9. If you now try to Append that same group it won't work either. This causes big problems when you've got a scene that requires a certain group to be appended. But once this mistake is made there's no way to go back. You can never append that group into the .blend.
Author
Author
Added subscriber: @AndrewPrice
Sergey Sharybin self-assigned this 2014-02-18 06:30:49 +01:00
Added subscriber: @ideasman42
This isn't a bug, notice the last option Instance Groups is off by default when you select Link but not Append from the menu.
The logic is:
  • if you append the original objects will be added to the scene so no need to instance groups.
  • if you link then the original objects are in another blend file so instancing the group makes more sense.
When you link an already linked group it wont add a new instance, thats also intentional - but confusing in certain cases like this.
This isn't a bug, notice the last option **Instance Groups** is off by default when you select **Link** but not **Append** from the menu. The logic is: - if you append the original objects will be added to the scene so no need to instance groups. - if you link then the original objects are in another blend file so instancing the group makes more sense. When you link an already linked group it wont add a new instance, thats also intentional - but confusing in certain cases like this.
Author
Ah I see. So could the two options be tethered then to avoid confusion? Like when you click Link, Instance Groups is automatically checked too?
Seems others on twitter have been confused by this too.
Ah I see. So could the two options be tethered then to avoid confusion? Like when you click Link, Instance Groups is automatically checked too? Seems [others on twitter ](https://twitter.com/andrewpprice/status/435640517041209344) have been confused by this too.
We could, but they are not really related. instancing a group can be done with/without linking.
Think it may be better to remove the Link option (Blender 2.4x didnt have this). then you just have to use the right menu item and reasonable defaults will be set for each.
We could, but they are not really related. instancing a group can be done with/without linking. Think it may be better to remove the **Link** option (Blender 2.4x didnt have this). then you just have to use the right menu item and reasonable defaults will be set for each.
Author
That sounds like a good idea. Removing the option would stop the mistake from happening all together.
Cheers!
That sounds like a good idea. Removing the option would stop the mistake from happening all together. Cheers!
Exactly (less is more blah blah :) ) - but in this case it works...
OK, re-opened this but can postpone until after 2.70 since its not really urgent.
Exactly (less is more blah blah :) ) - but in this case it works... OK, re-opened this but can postpone until after 2.70 since its not really urgent.
Added subscriber: @brecht
Sergey Sharybin was unassigned by Campbell Barton 2014-02-19 05:19:12 +01:00
Campbell Barton self-assigned this 2014-02-19 05:19:12 +01:00
Author
Thanks guys much appreciated :)
Committed 23b4e246e3
closing
Committed 23b4e246e3 closing
Reference: blender/blender#38695
