Rendering artifacts with volumetrics + object texture with alpha transparency
Windows 7 professional
Intel Core i7-2600
Geforce 560Ti
Broken: 2.69.10 cc7cfd6
When an object with textured alpha transparency is inside a volumetric object, its transparent areas show up in a weird way.
Also, some weird light streak appears inside the volume. The errors might to be related, because if I delete the objects inside the volume, the streak goes away.
Attached image for clarification.
Open my attached scene, and activate viewport rendering.
Or:
Add a cube. Set up a volumetric scattering material. (Absorption type doesn't have this error.)
Add a plane. Set up a material with clearly visible transparent areas. Place inside cube.
Add a light source.
Render.
Sakari Leppä (Zagupi) raised the priority of this task from to 90.
Sakari Leppä (Zagupi) updated the task description. (Show Details)
Sakari Leppä (Zagupi) edited a custom field.
Thomas Dinges (dingto) lowered the priority of this task from 90 to Normal.Feb 19 2014, 12:56 AM
Confirmed the problem.
@Brecht Van Lommel (brecht): Does not happen with CMJ, problem only occurs with Sobol.
Brecht Van Lommel (brecht) triaged this task as 50 priority.Feb 26 2014, 4:33 PM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Feb 26 2014, 6:49 PM
Closed by commit rBe1e247a99b48.
