Mask scaling not working
Closed, InvalidPublic
Windows 7, Nvidia Quadro 4000
Broken: Hash 4789793
Worked: r61232
Selecting all the vertices of a mask and scaling does NOT scale the entire mask. If handles are set to Aligned, you can see it scaling the handles. In r61232, the entire mask scales.
Go to masks, add circle mask, press S to scale. Nothing happens.
Sean Kennedy (hype) raised the priority of this task from to Needs Triage by Developer.
Sean Kennedy (hype) updated the task description. (Show Details)
Sean Kennedy (hype) set Type to Bug.
This is caused the the default pivot point of the movie-clip editor being set to individual origins.
You can change the pivot point type and scaling will work as you expect.
closing
