Crop node doesnt work procedurally #38850
Reference: blender/blender#38850
OSX 10.8.4
Broken: in both official 2.69 release and trunk build 27/02/14
cf0120b
The crop node gets the input size/position from the original image size, not from the node being piped into it.
if you look at the attached blend file. disabling the scale node, you can see the crop is taking its dimensions from the input image, not from the scaled image.
In the bottom node tree, you can see the crop takes no notice of any transforms applied to the image.
expected behaviour would be the crop is based on 1) the output image dimensions, or ideally 2) the new dimensions of the image after it has been scaled.
crop_bug.blend
Added subscriber: @LevonHudson
Added subscriber: @LukasTonne
"Size" in the compositor is badly defined, but not really a bug: When the crop node uses relative borders this is based on the resolution of the image. This resolution is exactly the same for the input image and the scale/translate node outputs. This is awkward behavior in itself, but it is necessary because the compositor has no other way of defining the relation of different images and node results to each other currently.
The only solution really is to implement proper canvas compositing, which defines a common "canvas space". Nodes can then have pixel resolutions on top of that to do proper sampling.
Until then this must be considered intentional, although undesirable and limiting ...
