MARK Seam/Sharp (edge) command in search menu not always MARKs (sometime it CLEARs) #38856
Reference: blender/blender#38856
Ubuntu 12.04 / NVIDIA GeForce 310
Broken: (example: 2.69.7
4b206af
, see splash screen)Worked: (optional)
2.7(test build release) : Hash:
10f4c62
Marking and clearing sharp/seam edges.
Using the (space) search menu to "Mark Sharp/Seam" after a CLEAR sharp/seam command was executed, will not actually MARK, but CLEAR the sharp/seam edge instead.
Note: Based on a irc chat with ideaman42 he indicates that there is one operator for clear/mark edges, and the clear vs sharp is defined via a parameter. This discussion was related thought to the reason why only the Mark Sharp/Seam command is listed in the search menu, but there is none for Clear Sharp/Seam (though it should, IMO). I suspect that this missing search menu entry and this currently reported bug are related.
executing the menu/mark sharp on any other edge will do nothing since (i suspect) it is calling the Clear Sharp (instead of the Mark Sharp)
(same steps apply to mark/clear seam)
Added subscriber: @MariusGiurgi
This issue was referenced by blender/blender-addons-contrib@59a0828ac1
59a0828ac1
Closed by commit
59a0828ac1
.Added subscriber: @brecht
Thanks for the report, fixed this behavior now.
I have not added the clear seam operator to the search menu, this will require some bigger changes. At the moment clear and mark seam are a single operator with a "clear" setting you can toggle. At some point we might want to make the same operator with different settings available in the menu, but that's not supported at the moment.
Added subscribers: @ideasman42, @dfelinto
@brecht see related discussion: #38819 and
d47d0302
(reverted here:073a1f8f
). And, well, D350cc: @ideasman42
Ah well, in the past I have solved more such cases by simply adding PROP_SKIP_SAVE. To me that seems like the right solution in the current system, if there is a property that totally changes the tool so that the description no longer covers it, then we just don't remember it.
We could figure out a better convention, maybe always splitting this into multiple operators or somehow exposing multiple variations of an operator in the search menu. But I think that adding PROP_SKIP_SAVE is a net improvement.
