Unstable behavior using VehicleWrapper in blender 2.70 test build #38895
6 Participants
Reference: blender/blender#38895
Ubuntu 13.10
'GeForce GT 425M/PCIe/SSE2'
Broken: (Blender 2.69 (sub 11) Hash
10f4c62
, Blender 2.69 (sub 10) Hash2038eb1
Linux:64bit)Worked: (Blender 2.69 (sub 0) Hash 60991 , Blender 2.66 (sub 1) Hash 55252 Linux:64bit)
Works fine in previous versions, but the same file in the test build for 2.70 makes the wheels jump continuously
add a 'Cube' add 4 Cylinders to use has wheels, rotate and aply rotation, make the apropriate logic brick to use the script(you may use the one provided in the blend file, add a 'plane' to use has a ground, change to game engine, set wheels to 'no collision' in the physics panel, the 'cube' to 'rigidbody'. Press 'p'. The 'vehicle should fall to the plane and stop. The behaviour seen in the newer version is that the wheels don't stop jumping.
Note: this behaviour happens with other values with different configurations(meshes, mass, sizes, etc)
I'm just providing this file has a test of the problem. Not sure if this is a bug or some change was made to the game engine physics to correct previous bugs and now this is the new expected behavior.
test_bug_270.blend
More instructions are in the blend file attached.
Added subscriber: @HugoBarreira
Just noticed that it's also broken in,
version 2.69 (sub 10), '2014-02-10' , hash '2038eb1', Linux:64bit
worked in
version 2.69 (sub 0), revision b'60991'.2013-10-29', Linux:64bit
version 2.66 (sub 1), revision b'55252'.'2013-03-14', Linux:64bit
Added subscriber: @brita
I can confirm this with the current master.
This is assertion is failing:
blender-source/extern/bullet2/src/BulletDynamics/Vehicle/btRaycastVehicle.cpp:384:
void btRaycastVehicle::applyEngineForce(btScalar, int): Assertion `wheel>=0 && wheel < getNumWheels()' failed.
Added subscribers: @sreich, @Moguri
Sergej, you seem to be our resident Bullet expert. I have tracked down the issue to the 2.82 Bullet update. We are running into the issue mentioned in this thread: http://bulletphysics.org/Bullet/phpBB3/viewtopic.php?t=9662. It seems prior to Bullet 2.82 the default btConvexCast for btCollisionWorld::rayTestSingleInternal() was set to btSubsimplexConvexCast via compiler prgamas (#ifdef, etc). However, in Bullet 2.82 btGjkConvexCast became the default.
So, my question to you is, should we force using btSubsimplexConvexCast, or do we try to figure out why btGjkConvexCast doesn't work for us? The following patch will force the BGE to use btSubsimplexConvexCast for its vehicles:
bge_vehicle_simplex.diff
Using the old raycast method should be fine, we did that for #37673 as well.
This issue was referenced by
2e20c16897
Closed by commit
2e20c16897
