Macintosh osX lion 10.7.5, no graphics card
Broken: (example: 2.69.7 4b206af, see splash screen)
2.7 (Date 2014-02-20 05:32) 4789793
Bevel on starter cube in edit mode causes crash. A single cut is possible but when or after some segments have been added using F6 a crash occurs. The tool does not reset either, meaning that when applying a second bevel it generates more than one indent at once.
Create a base cube, go into edit mode on it. apply a bevel to an edge, left click. press F6 slide to max, add four segments, make them outward fully. click the vertex tab. Repeat this process after or prior to cleaning up the ngons. The crash for my system occurs on trying to increase or decrease amount. thanks
Comment Actions
Can't reproduce on OSX.
So to clarify, you are saying it is broken on 2.69.7, but works on 2.7 4789793?
Comment Actions
Yes, confirm that is breaking in 2.7 release candidate.
But that bug was fixed in T38742
If you download the latest build from BuildBot you will see it is fixed.
