Shortcut keys inconsistent.
Closed, InvalidPublic
OSX 10.7
Blender Trunk build 2.69.11
In node editor working with cycles shaders. When creating new glossy shader you can use shortcut keys Shift-A (brings up add window), H (select shaders tab), G (adds Glossy Shader).
In Materials tab in Properties. In Surface, opening shader dropdown and using shortcut G gives you a Glass shader. NOT A GLOSSY SHADER. Please make shortcuts consistent.
Thanks,
Jonathan Lax
Gecko
Jonathan Lax (laxy24) raised the priority of this task from to 90.
Jonathan Lax (laxy24) updated the task description. (Show Details)
Jonathan Lax (laxy24) edited a custom field.
Lukas Toenne (lukastoenne) lowered the priority of this task from 90 to Low.Mar 5 2014, 12:56 PM
This picks the first menu item by name. Menu in the materials tab needs to use the same system as the shift+a menu in the node editor.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Jun 3 2014, 9:02 AM
On the other hand shortcuts are automatically geenrated for menus, we don't really control them. It's probbaly possible to improve behavior here but making a general ystem which would keep shortcuts between multiple menus consitent is rather really tricky.
Moving to TODO now: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Menu
