Bevel modifier. Сombination Segment and Profile creates a bulge.
Windows 8.1 x64
GForce GTX 560
Broken: 2.7 2d4de27
Sorry for my English, I use the Google translator.
I loved the new features Bevel modifier, use it for hardsurfece modeling.
But I ran into a problem on surfaces, which are at an angle, this modifier creates a bulge.
For example, if you add the number of segments to 4, and set equal to 1 Profile
So3Datel (AxelMening) set Type to Bug.
So3Datel (AxelMening) created this task.
So3Datel (AxelMening) raised the priority of this task from to Needs Triage by Developer.
Don't really know if this could be considered a bug, but I can confirm it. Seems to work fine on the default cube, but rotate one of the faces or bevel and edge (in edit mode) and it'll have those bulges
Bastien Montagne (mont29) triaged this task as Normal priority.
Yes, I know about this. It is hard to get the profile=1 case to work right using the general purpose code for profiles. I special cased orthogonal corners, but really need to make a whole different code for this. So currently I call it working as intended, but a TODO to improve this (also to make the profile=0 case work, which also requires special case code).
Howard Trickey (howardt) closed this task as Archived.Mar 18 2014, 4:10 PM
