Smart UV in 2.70 RC
iMac 3.4Ghz
Core i7
12GB ram
System: 10.8.5
Broken: Blender 2.70 RC - Smart UV
When creating a smart UV using defaults, the UV mesh is fragmented unreasonably. This occurs only in the 2.70 RC as earlier versions of Blender seem fine. See atached image. The upper image is 2.70 and lower image is 2.68a.
This may simply be an issue with the RC but I thought it worth reporting.
James Allan (shamusboy) set Type to Bug.
James Allan (shamusboy) created this task.
James Allan (shamusboy) raised the priority of this task from to Needs Triage by Developer.
As i could reproduce the same problem with a dyntopo dense mesh , i'm adding more informations :
In Blender 2.69 "stable" , the uv smart has no problem unwrapping everything with my dense mesh.
In Blender 2.70rc , the smart uv fail to unwrap a lot of its faces and those failures are then all merged into a single point in the uv map, on the bottom left (same as you can seeon shamusboy screenshot), it's very bad.
I uploaded the blend i tried on both version here if you need one to reproduce the bug :
http://www.pasteall.org/blend/27558
@Campbell Barton (campbellbarton) this is apparently caused by rBe781ea79. By reverting this change I don't the error explained above.
