2.70 CUDA Error: Not found in cuModuleGetTextRef(&texref,cuModule, name)
Windows 7 x64 16GB memory GTX Titan
Broken: 2.70 2014-03-18 00:07 Hash: eaf387b
Unable to render using Cycles or to use viewport shading of Rendered
Open blend file
Change viewport shading to Rendered
Stan long (stanlong) updated the task description. (Show Details)
Stan long (stanlong) raised the priority of this task from to Needs Triage.
Stan long (stanlong) set Type to Bug.
Thomas Dinges (dingto) triaged this task as Normal priority.Mar 18 2014, 6:57 AM
Thomas Dinges (dingto) updated the task description. (Show Details)
Juicyfruit, can you check please? As this error only occurs after 2.70, it might be related to the interpolation changes?
I cannot reproduce this using non titan + hack to set use_texture_storage to true (to simulate sm 35 card)
I will try this tomorrow on GTX 780.
Same issue here with GTX Titan, Ubuntu 12.04 64bits, and Blender 930765f 64bits
I think I have found the problem. Need to test tomorrow and hopefull first reproduce then fix the problem
I'm not an expert but i have the same issue on sm_50, but i use cuda toolkit v6.0 to build the kernel for the GTX750ti.
But i think this also applies to sm_35, so i told it dingto.
I reproduce it with a sm_20 kernel on the GTX570, which was built with the CUDA toolkit v5.0, to exclude this possibility it is the "cuda 6.0/sm50"
For this, i have change :
device_cuda.ccp
225 		use_texture_storage = (cuDevArchitecture < 350)
225 		use_texture_storage = (cuDevArchitecture < 200)
kernel_compat_cuda.h
63		#if __CUDA_ARCH__ < 350
63		#if __CUDA_ARCH__ < 200
And it works :D i have the same problem with the gtx570
on simple Scene or total crash on more complex scene
