Inset going nuts
XP SP3
Broken: 2.70 stable release
Worked: 2.69
On that simple mesh the insetting is getting out of hand
  • load Blender 2.70 stable
  • File -> Load Factory Settings
  • File Open -> Load UI disabled and then load the attached blend.
  • Go into front Right View (Numpad 3) in Edit Mode
  • Select all if it's not already selected
  • Press I to inset and move the mouse , the mesh go nuts
If i load that blend in 2.69 stable , while it's not going to get a satisfying{F81952} result, at least the mesh does not explode.
Note : Inset individual (pressing 2 times I ) works without a problem in every versions.
Sanc Tuary (sanctuary) set Type to Bug.
Sanc Tuary (sanctuary) created this task.
Sanc Tuary (sanctuary) raised the priority of this task from to Needs Triage by Developer.
looks like i can't edit what i wrote, so
was meant to be
Go into Right View (Numpad 3) in Edit Mode
and the attached file ( F81952 ) for some reason has placed itself just after the word "satisfying" despite i didn't dragged it there, i guess my browser settings are not friendly to those new scripts on that page
Some important additional note i found today while testing more :
I noticed after pressing I, having then the inset "exploding" and pressing enter/right click to apply it that if i press F6 (or look into the operator) and disable "Edge Rail" that is an option by default, the inset does not explode anymore.
In Blender 2.69 in which the inset does not explode (but is not making a good result on the provided mesh) that the Edge Rail option does not exist in the Inset operator
And probably important, in 2.70 that make the inset explode, if i disable that new "Edge Rail" setting, the inset is really good on that mesh, nothing in common with the bad result of 2.69
Campbell Barton (campbellbarton) raised the priority of this task from Confirmed, Medium to Unbreak Now!.Mar 28 2014, 2:35 AM
This is really bad. somehow it didnt show up in my tests, will look into a fix today for 2.70a
