Applying Laplacian Deform as a shape key breaks the original mesh
Closed, InvalidPublic
Version: 2.70 official (win 64)
How to reproduce:
Inspect the "Worm" mesh and apply the laplacian deform modifier as a shape key. Notice that applying the modifier leaves behind the messed up basis mesh. The shape key created is relative to that messed up basis.
Expected Behavior:
Technically, this IS the expected behavior! But it's not useful. Applying the Laplacian Deform Modifier as a shape key should restore the mesh to the original shape to which the modifier was bound (in this case, a perfectly straight rectangular prism), and the new shape key should be relative to that original shape. This makes it possible for a modeler/rigger/animator to create shape keys with laplacian deform while preserving the original shape of the mesh.
Sam Brubaker (rocketman) set Type to Bug.
Sam Brubaker (rocketman) created this task.
Sam Brubaker (rocketman) raised the priority of this task from to Needs Triage by Developer.
Bastien Montagne (mont29) triaged this task as Normal priority.
I’m not quite sure this is a bug, would rather say it’s a feature request… See how it’d be better behavior, though.
Will let Campbell decide!
Its true that there isnt really a good way to use Apply As Shape with Laplacian Deform.
In this case you really want to take a few things into account.
  • The rest.
  • The deformation.
  • The laplacian result.
I had a look into this and while we could add special support for this, I think in fact you want to apply the combine result as a new shape (rather then a single modifier).
You can:
  • add a basis key (the rest)
  • add a shape (the deformed state)
  • deform the first key to get some useful result from laplacian deform
  • in the shape key menu select New Shape From Mix
closing.
