Titles on frame nodes are difficult to see with a colored background #39317
Closed
opened 2014-03-21 11:58:10 +01:00 by Eduardo Maldonado · 7 comments
Windows XP 32bit, ATI RADEON HD 4500
Broken: 2.70.0 19e627c
Worked: 2.69.0
Something has changed in the color of the header on a frame node. It is taken the "Text" color of the Themes setup, so it is black. If I set a text label and a color for my frame, the header is not visible enough. Before it took a clear color (I don't know from which feature it came).
If I change the "Text" color, then the text of the nodes will be difficult to see.
  1. Add a frame.
  2. Set label color for the frame. As the header
**System Information** Windows XP 32bit, ATI RADEON HD 4500 **Blender Version** Broken: 2.70.0 19e627c Worked: 2.69.0 **Short description of error** Something has changed in the color of the header on a frame node. It is taken the "Text" color of the Themes setup, so it is black. If I set a text label and a color for my frame, the header is not visible enough. Before it took a clear color (I don't know from which feature it came). If I change the "Text" color, then the text of the nodes will be difficult to see. **Exact steps for others to reproduce the error** 1. Add a frame. 2. Set label color for the frame. As the header ![node_frame_269.png](https://archive.blender.org/developer/F82073/node_frame_269.png) ![node_frame_270.png](https://archive.blender.org/developer/F82076/node_frame_270.png)
Added subscriber: @EduardoMaldonado
Member
Added subscriber: @LukasTonne
Member
Here's the commit 80f3956972
I will leave the decision up to the UI team how we want to determine frame label colors. Can do the implementation, but no idea what would work in all cases here ...
Here's the commit 80f3956972 I will leave the decision up to the UI team how we want to determine frame label colors. Can do the implementation, but no idea what would work in all cases here ...
Member
Lukas Tönne self-assigned this 2014-03-23 12:37:37 +01:00
Member
I'm putting this on the ToDo list. Best solution would be to draw the text with 2 colors, an brighter main color with a dark outline, to give sufficient contrast in all cases. Unfortunately seems we don't have any precedence for this yet, could be a bit tricky to implement.
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Editors#Node_Editor
I'm putting this on the ToDo list. Best solution would be to draw the text with 2 colors, an brighter main color with a dark outline, to give sufficient contrast in all cases. Unfortunately seems we don't have any precedence for this yet, could be a bit tricky to implement. http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Editors#Node_Editor
Further details:
In 2.69 the color of the frame label was in Theme Node Editor >> Node Backdrop
In 2.70 the color of the frame label is in Theme Space Settings >> Text
A fast solution for me is put that Text property in a clear color, for example white, but all the text inside the nodes uses this setting.
You can see these screenshots:
Further details: In 2.69 the color of the frame label was in *Theme Node Editor >> Node Backdrop* In 2.70 the color of the frame label is in *Theme Space Settings >> Text* A fast solution for me is put that Text property in a clear color, for example white, but all the text inside the nodes uses this setting. You can see these screenshots: ![label_frame_269.png](https://archive.blender.org/developer/F82373/label_frame_269.png) ![label_frame_270.png](https://archive.blender.org/developer/F82375/label_frame_270.png)
2 Participants
Reference: blender/blender#39317
