Optimal Display overriden in a modifier stack #39350
2 Participants
Reference: blender/blender#39350
xp sp3
Broken: all 2.6x- 2.7 versions i tested
Worked: Blender 2.49b
if you enable Wire and Draw All Edges (in the Object panel on the right of the screen) on an object that has a Subdivision surface modifier or a Multiresolution modifier, and enable Optimal Display on the modifier, as you expect the wire displayed is the one from the level 0 of the subsurf/multires
But if you add a shrinkwrap modifier that target another object, the Optimal Display is overriden and all the edges will always be displayed, regardless if Optimal Display is enabled or not
so far good
after doing that, you'll see that suddenly all the edges are displayed, despite you have the Optimal Display enabled.
to speed up, just load the blend i attach here that has all the steps already done if i'm not clear enough :
optimaldispedge01.blend
Added subscriber: @sanctuary
Added subscriber: @mont29
In fact, this is not a bug, rather an internal limitation. This feature can only work as long as subsurf data are available from modifier stack - if another modifier down in the stack replaces it for some reason, this simply cannot work. Thanks for the report, anyway.
