Driver controlled value not updates properly during animation - it has 1 frame lag #39393
Reference: blender/blender#39393
Kubuntu Linux 13.04 64bit, AMD Radeon HD 4670 graphics
Broken: tested in 2.70 official release (2014-03-19, hash
19e627c
), 2.68a, 2.61Worked: n/a
animation playback in viewport and during rendering
of animation. Usually it has 1 frame lag.
P.S. Driver controlled value is updated by select-grab-esc
of any bone of the armature under consideration.
In attached .blend:
Description of rig setup:
anim_driver_bug.blend
Added subscriber: @AleksanderTarkhanov
Added subscriber: @rocketman
I'd like to add that this seems like a widespread issue in Blender. Often when an object's property is driven by another property of itself, there seems to be a lag of one logic tick, even though the dependency is not cyclic. This bug can be reproduced simply by driving the rotation of an object by its location. The "extra object/data update" hacks do not appear to remedy this.
I would call this a pretty critical bug, as it can impede many advanced rigging techniques.
Added subscriber: @koilz
Ive run in to this problem a few times.
There is a work around, you can set the Driver Variable Space to Transform Space.
This should make blender update correctly.
Heres a modified example: anim_driver_bug2.blend
I dont know if your original example is a bug or not.
I dont know much about how the bone properties are suppose to be updated with the bones in pose mode.
Though I know different bone setups (If a bone has a parent or not) work correctly when using different Driver Variable Space.
The setup you're using leads to a fake cycle which is only resolvable with more granular dependency graph which we're working on.
Thanks for the report, but it's considered a TODO for now.
Hi!
to rocketman,
yes, adding "extra object" to the chain just gives a clear "dependency cycle"... but behaviour is the same... i.e. my setup is really looks like fake dependency cycle in Blender. And I don't know what to try with "data update" - so I'll just believe that's not helps.
to koilz,
yes, switching to Transform Space gives a solution, but I don't understand the background - it looks like magic!
to sergey,
now I see that my setup is really looks like fake dependency cycle and splitting armature object in two seems a reasonable solution. On the "Object level" Blender will tell me when I'll get into "true" dependency cycle, I think.
More versatile dependency graph would be great! Nice to hear that it is among TODO's.
Thanx a lot to all of you, guys! Now I know a much more about the problem and have a workaround, and not just one!
