Errors inside an property update method aren't reported to the UI, only to terminal #39406
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#39406
OS: Ubuntu 13.10
Linux kernel: 3.11.0-18-generic
Broken: blender-2.70-b66a954-linux-glibc211-x86_64
If an addon has an error that occurs at runtime, there is an error message in the user interface (pop-up box and report in the Info window header). However, if the error occurs inside an "property update method", the user is not notified.
Example file: update_bug.blend
Added subscriber: @Garrett-8
This is a limitation with our RNA data API. if an FCurve changes a value, or a button... and a python error occurs, there is simply no report list passed.
When you write update callbacks you are interfacing blender at quite a low level, same goes for python drivers.
closing.
since this isnt an error in blender and we're not likely to support this.
if you're developing with python you need to run blender from a terminal.
