Vertex connect doesn't work in some cases #39418
Reference: blender/blender#39418
Win7 64 bit
Broken:
b66a954
Sometimes on n-gons the vertex connect function doesn't work (standard shortcut J, or Mesh > Vertices > Connect from the menu)
See the file. Try to vertex connect the selected vertices.
On the screenshot, I marked a topologically similar pair of vertices where it works.
{F82568}vertexconnect.blend
PS: The file drag drop thing in the bug tracker doesn't work in Opera. Please add a standard Upload dialogue if possible, so that Opera users don't have to switch to Firefox just because of a bug report.
Added subscriber: @AnnaCelarek
Added subscriber: @gwentiv
I could reproduce it on both 2.69 and 2.70 Win 7 64.
If you make the ngon less "twisted" (for example moving the 2 vertices just underneath a bit to the left on the x axis), you'll eventually be able to create the junction.
Another file as example here{F82577}
Have a look at vertex groups
There seems to be a limit value in terms of the angles that the future "edge-to-be" will mark.
If you move the "to move" vertices a bit to the right so that the angle of the "edge-to-be" is sharper, you won't be able to use Ctrl J on the vertices of the future "edge to be".
I don't know if that's a bug or some limitation of ngons ?
Hi, there are some checks blender does to make sure it can split a face, and perhaps these checks need to be tweaked.
However this face is extremely distorted.
I'll check if its reasonable to support this case.
We could have a rule that if a face only has 2 of its vertices selected - always split in half. no matter what the shape of the face is.
Thanks for checking !
I can't think of a situation where splitting wouldn't in fact de-twist and relax the ngon…?
Added subscriber: @mont29
Changed behavior, 2 vertex selections now always connect.
5256a5d66c
So the example now works, rationale is - if you only select 2 vertices then you know what you do, so connect vertices even if it make create odd shapes.
Thanks! This makes it so much easier to fix distorted faces.
