Mask modifier not working in VSE
OSX 10.9.2
Broken: 2.70 b'859039f'
Adding an image sequence mask to a stip in the VSE doesn't currently work.
  1. Add image sequence strip in the VSE
  2. Add another black & white (B&W) image sequence strip in the VSE to be used for masking
  3. Place B&W strip above strip to be masked
  4. Hide B&W strip
  5. Select image sequence to be masked
  6. Add a mask modifier from the side panel (Add Strip Modifier/Mask)
  7. Choose B&W strip in the mask input field for the mask strip modifier
  8. Mask doesn't work.
System info generated by Blender:
Blender 2.70 (sub 0) System Information
Blender:
version 2.70 (sub 0), branch b'master', commit date b'2014-03-27' b'09:29', hash b'859039f', b'Release'
build date: b'2014-03-27', b'09:52:50'
platform: b'Darwin'
binary path: '/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/blender'
build cflags: b' -Wall -Werror=declaration-after-statement -Werror=implicit-function-declaration -Werror=return-type -Wno-tautological-compare -Wno-unknown-pragmas -Wno-char-subscripts -Wstrict-prototypes -Wmissing-prototypes -Wunused-parameter -mmacosx-version-min=10.6 -msse2 -msse -pipe -funsigned-char'
build cxxflags: b' -Wall -Wno-tautological-compare -Wno-unknown-pragmas -Wno-char-subscripts -Wno-overloaded-virtual -Wno-sign-compare -Wno-invalid-offsetof -mmacosx-version-min=10.6 -D__STDC_CONSTANT_MACROS -ftemplate-depth=1024 -msse2 -msse -pipe -funsigned-char'
build linkflags: b'-fexceptions -framework CoreServices -framework Foundation -framework IOKit -framework AppKit -framework Cocoa -framework Carbon -framework AudioUnit -framework AudioToolbox -framework CoreAudio -framework QTKit -liconv'
build system: b'CMake'
Python:
version: 3.3.3 (default, Nov 25 2013, 20:20:09)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.2.79)]
paths:
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/scripts/addons_contrib'
'/Users/stephen/Library/Application Support/Blender/2.70/scripts/addons'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/scripts/addons'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/scripts/startup'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/scripts/modules'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/python/lib/python33.zip'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/python/lib/python3.3'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/python/lib/python3.3/plat-darwin'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/python/lib/python3.3/lib-dynload'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/python/lib/python3.3/site-packages'
'/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/scripts/addons/modules'
'/Users/stephen/Library/Application Support/Blender/2.70/scripts/addons/modules'
Directories:
scripts: ['/Users/stephen/blender-build/build_darwin/bin/blender.app/Contents/MacOS/2.70/scripts', '/Users/stephen/Library/Application Support/Blender/2.70/scripts']
user scripts: '/Users/stephen/Library/Application Support/Blender/2.70/scripts'
pref scripts: None
datafiles: '/Users/stephen/Library/Application Support/Blender/2.70/datafiles/'
config: '/Users/stephen/Library/Application Support/Blender/2.70/config/'
scripts : '/Users/stephen/Library/Application Support/Blender/2.70/scripts/'
autosave: '/Users/stephen/Library/Application Support/Blender/2.70/autosave/'
tempdir: '/tmp/'
FFmpeg:
'avcodec':' ''53, 60, 100'
'avdevice':' ''53, 4, 100'
'avformat':' ''53, 31, 100'
'avutil':' ''51, 34, 101'
'swscale':' '' 2, 1, 100'
Other Libraries:
OpenColorIO: 1, 0, 7
OpenImageIO: 1, 3, 9
OpenShadingLanguage: 1, 4, 0
renderer: 'Intel HD Graphics 4000 OpenGL Engine'
vendor: 'Intel Inc.'
version: '2.1 INTEL-8.24.11'
extensions:
		'GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp'
		'GL_ARB_depth_texture GL_ARB_draw_buffers'
		'GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced'
		'GL_ARB_fragment_program GL_ARB_fragment_program_shadow'
		'GL_ARB_fragment_shader GL_ARB_framebuffer_object'
		'GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel'
		'GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample'
		'GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object'
		'GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex'
		'GL_ARB_seamless_cube_map GL_ARB_shader_objects'
		'GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow'
		'GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression'
		'GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map'
		'GL_ARB_texture_env_add GL_ARB_texture_env_combine'
		'GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3'
		'GL_ARB_texture_float GL_ARB_texture_mirrored_repeat'
		'GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle'
		'GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra'
		'GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program'
		'GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra'
		'GL_EXT_blend_color GL_EXT_blend_equation_separate'
		'GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract'
		'GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker'
		'GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord'
		'GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample'
		'GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB'
		'GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters'
		'GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays'
		'GL_EXT_packed_depth_stencil GL_EXT_packed_float'
		'GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color'
		'GL_EXT_separate_specular_color GL_EXT_shadow_funcs'
		'GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array'
		'GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc'
		'GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic'
		'GL_EXT_texture_integer GL_EXT_texture_lod_bias'
		'GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent'
		'GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query'
		'GL_EXT_transform_feedback GL_EXT_vertex_array_bgra'
		'GL_APPLE_aux_depth_stencil GL_APPLE_client_storage'
		'GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels'
		'GL_APPLE_flush_buffer_range GL_APPLE_flush_render'
		'GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer'
		'GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector'
		'GL_APPLE_texture_range GL_APPLE_transform_hint'
		'GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range'
		'GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators'
		'GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3'
		'GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip'
		'GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp'
		'GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection'
		'GL_NV_texture_barrier GL_SGIS_generate_mipmap'
		'GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod '
stephen thomas (stephenthomas0) raised the priority of this task from to Needs Triage by Developer.
Sergey Sharybin (sergey) triaged this task as Normal priority.
I'm not sure why exactly you consider the mask modifier doesn't work in the attached file?
Ah, just did a render and I can see that the masking is just not showing in the VSE preview window. See the attached screen shot (VSE above, render below).
I couldn't confirm the issue with the file you've attached actually. Both preview and final render works fine here.
Also worth testing fresh builds from builder.blender.org.
Ah yeah, build from builder.blender.org works fine. Sorry about that, must be something happening in the build I'm making from git. I'll be sure to check that next time before taking up your time. Also, the new bug tracking system is really nice, very fancy. Keep up the good work :)
