bevel modifier behave weird with screwed object #39486
Closed
opened 2014-03-28 14:48:26 +01:00 by Jakub Strykowski · 14 comments
Broken: 2.70 official
**Showed on image, when profile is not rotated bevel looks good, but when rotate by 45' it makes mess
{F83212}bevel_bug.blend
**Blender Version** Broken: 2.70 official **Showed on image, when profile is not rotated bevel looks good, but when rotate by 45' it makes mess {[F83212](https://archive.blender.org/developer/F83212/bevel_bug.jpg)}[bevel_bug.blend](https://archive.blender.org/developer/F83214/bevel_bug.blend)
Added subscriber: @cenobi
#40100 was marked as duplicate of this issue
#39499 was marked as duplicate of this issue
Added subscriber: @mont29
Howard Trickey was assigned by Bastien Montagne 2014-03-28 15:23:25 +01:00
Added subscribers: @alihakkidemiral, @gwentiv
◀ Merged tasks: #39499.
Member
I agree that something funny is going on here, and will try to debug it.
Member
Finally looked at this. Uploaded another .blend that is easier to test with.
screw.blend
The problem is that the twist means that there is no perfect place for the beveled verts to go such that the offset distance from the original edge is the spec, at both ends. So it chooses a compromise place that happens to make the one side about 2% too wide and the other about 2% too narrow. There is an adjustment pass that tries to make both ends of the bevel have the same width. Unfortunately, that pass keeps making one side 2% narrower and the other side 2% wider at each edge. After several hundred edges, one side seems to have almost zero width, and the other side is much bigger than the spec.
I need to either (1) find a smarter algorithm for the width adjustment that doesn't allow this accumulation; or (2) add an option to "not try to adjust widths". The latter would fix this case but it is really annoying to accumulate flags whose only purpose is to work around problems that otherwise occur. So will try for a smarter algorithm first.
Finally looked at this. Uploaded another .blend that is easier to test with. [screw.blend](https://archive.blender.org/developer/F98710/screw.blend) The problem is that the twist means that there is no perfect place for the beveled verts to go such that the offset distance from the original edge is the spec, at both ends. So it chooses a compromise place that happens to make the one side about 2% too wide and the other about 2% too narrow. There is an adjustment pass that tries to make both ends of the bevel have the same width. Unfortunately, that pass keeps making one side 2% narrower and the other side 2% wider at each edge. After several hundred edges, one side seems to have almost zero width, and the other side is much bigger than the spec. I need to either (1) find a smarter algorithm for the width adjustment that doesn't allow this accumulation; or (2) add an option to "not try to adjust widths". The latter would fix this case but it is really annoying to accumulate flags whose only purpose is to work around problems that otherwise occur. So will try for a smarter algorithm first.
Member
Added subscribers: @00Ghz, @MarcClintDion, @howardt, @JulianEisel
Added subscriber: @Inwader77
This issue was referenced by 0c420a2e49
This issue was referenced by 0c420a2e496963c3f2730333a2c09f788efba39b
Member
Member
Note that I gave up trying to make an algorithm that works well in all cases. I could fix the bug in this report by clamping the amount of width adjustment in the global width adjustment path; but that made one of the regression tests look bad.
But I really didn't want to add a flag meaning "do global width adjustment" because I felt it would be hard to explain to users. Luckily, the 'Clamp overlap' flag already has a kind of similar meaning -- "don't let the parameters get so out of control so as to make the result crazy". And also luckily, that flag is on by default in the bevel modifier. So I decided to have the clamping effect happen only when the "Clamp overlap" flag is on, which means that the bevel_bug.blend example in this bug now works fine.
Note that I gave up trying to make an algorithm that works well in all cases. I could fix the bug in this report by clamping the amount of width adjustment in the global width adjustment path; but that made one of the regression tests look bad. But I really didn't want to add a flag meaning "do global width adjustment" because I felt it would be hard to explain to users. Luckily, the 'Clamp overlap' flag already has a kind of similar meaning -- "don't let the parameters get so out of control so as to make the result crazy". And also luckily, that flag is on by default in the bevel modifier. So I decided to have the clamping effect happen only when the "Clamp overlap" flag is on, which means that the bevel_bug.blend example in this bug now works fine.
5 Participants
Reference: blender/blender#39486
