Translate node causes over gamut colors #39539
Reference: blender/blender#39539
Win 7 64bit
Broken: 2.70
b66a954
Adding translate node to a rendered layer causes bright out of gamut color bands. Also the translation effect doesn't redraw correctly, resulting in portions of the image wrapping around edges (even when wrap function is OFF).
Create a layer with alpha, add translate node then send to mix node. Alpha seems to be included weather I want it or not. Viewer Displays large red Chunks (they change size when I change the chunk render size). Composite output has no red blocks but has bad wrap from translate node.
.blend included.blast_test.blend
Added subscriber: @davidmcsween
Added subscribers: @Jeroen-Bakker, @LukasTonne
Looks like there are several different issues here:
Seems that the result outside the render resolution is not set (as Lukas mentioned) This was not always the case, so we should fix it.
Sorry for the late reply.
This issue was referenced by blender/blender-addons-contrib@5d51de3bea
5d51de3bea
Closed by commit
5d51de3bea
