Make force fields support solid objects
Confirmed, NormalPublicDESIGN
Currently, if a force field is created with a Surface shape, particles (and hair and cloth) will be attracted or repelled along the normals of the mesh. With a positive force, particles are always repelled away from the nearest face. This works well for surface meshes, i.e. where the faces are two-sided. However, it is not useful for simulating solid meshes.
For a solid mesh, the faces should be considered to be single-sided: the direction of the force should not change when the particle crosses the face, as shown in B in the following diagram.
  • A: Current behaviour: force direction always reverses at face boundary and at midpoint between faces. Particles can get trapped inside solid objects.
  • B: Proposed behaviour: force direction is consistent across face boundary, but still reverses at midpoint. Allows particles to be repelled from surface and pushed out from inside.
This .blend file demonstrates the problem: if the particles or cloth end up inside the cube, they never escape. Under this proposal they should be repelled, because the force field strength is positive.
If this is option is implemented, it could be exposed as a new option, or the Both Z / +Z / -Z options could be reused for it.
Alex Fraser (z0r) raised the priority of this task from to 90.
Alex Fraser (z0r) updated the task description. (Show Details)
Alex Fraser (z0r) added a project: BF Blender.
Alex Fraser (z0r) edited a custom field.
Thanks for the graph. I understand better.
In fact, force field shape is relative to preset form (sphere,tube,cube).
It could be good to have options to make it also relative to force field shape in theses cases Surface or Every Point.
Sergey Sharybin (sergey) lowered the priority of this task from 90 to Normal.Apr 11 2014, 8:54 AM
@Lukas Toenne (lukastoenne), summoning here in order to have a look :)
