lip sync blender 2.7 not working #39571
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#39571
Broken: (example: 2.69.7 4b206af, see splash screen)
Added subscriber: @MasonMenzies
what version are you using, you can verify that from pref. addons tab where you enabled it.
using 2.7
how do i enable it?
http://wiki.blender.org/index.php/Doc:2.6/Manual/Extensions/Python/Add-Ons
the version of the addon is 0.5.1 but when i try to enable it it just says
Trackback (most recent call last):
File "C:\Users\masonblenderrender\AppData\Roaming\Blend er Foundation\Blender\2.70\scripts\addons\io_import_l ipSync_importer.py" line 2
SyntaxError: invalid syntax
is there a way to fix this? i installed it like this link says but it's still not working.
Added subscriber: @ideasman42
A line starting with
<!--saved
is not valid python syntax, and looks like HTML or XML comment.Somehow you managed to have a py file with some HTML/XML in it.
This isnt a bug in Blender, and
io_import_lipSync_importer.py
is not distributed with official releases.closing.
so how do i fix it? i need this add on for a dead line or i'm kind of screwed. any idea how to fix or where to get a version that does not have <!--saved from url?
i need this soon. i redowloaded it 3 times now. idk what to do. is there a way i can just edit it? with note pad ++?
Added subscriber: @gwentiv
Of course, it's just text after all.
You can get rid of the comment and see if it works better.
Note, the script is from SVN and we've since moved to GIT, possibly the script wont run with a recent blender version.
SVN is kept online for reference only, dont use scripts from there.
some kid named mason (me) did not try right clicking on the link and saving it that way. i was clicking on it and then copying it and saving as py. i got it now. thanks.
